knock sensor shot
Old Jul 19, 2016 | 02:40 PM
elwood73's Avatar
knock sensor shot
knock sensor is shot on my 3vze unless the wires are frayed, of which i will check prior to going to deep into removal, but in the event i have to extract and replace the buried bastard, what else would some of you old school mechanics recommend me doing while I'm in there, already did the timing belt water pump and tensioner. just looking for a second opinion, thanks elwood
Old Jul 19, 2016 | 03:31 PM
91bluerunner's Avatar
The harness going to the sensor usually gets hard and brittle. Basically you only need intake gaskets, the knock sensor sub harness and the sensor might be good, but might as well replace it since your all the way down in there.
Old Jul 19, 2016 | 03:36 PM
But get an OEM sensor & harness if possible. I've had a lot of trouble with aftermarket knock sensors on the 3vze. The other issue I've seen is there's a different sensor up to 1988-91 than the 1992-95, so make sure you get the right one for your year.
Old Jul 19, 2016 | 04:00 PM
millball's Avatar
Cleaning/servicing or replacement of fuel injectors if high mileage.
Sporkinator
Mar 18, 2016 06:08 PM
splangeland
Mar 5, 2016 06:22 AM
128keaton
Feb 12, 2016 05:35 PM
Mikkydee
Jan 27, 2016 03:23 PM
PAVEYOTA
Jul 21, 2002 08:25 AM
