K&N... good or bad?
seems bobistheoilguy is not the only test of filters out there...
http://www.duramax-diesel.com/spicer/index.htm performed an ISO-5011 standard test on several filters.
...The AC Delco filter test ran for 60 minutes before exceeding the restriction limit while the AMSOIL and K&N tests each ran for 20 and 24 minutes respectively before reaching max restriction....
...Compared to the AC, the K&N “plugged up” nearly 3 times faster, passed 18 times more dirt and captured 37% less dirt....
...The stock filter will flow MORE THAN ENOUGH AIR to give you ALL THE HORSEPOWER the engine has to give....
Jnkml
Jul 6, 2015 01:20 PM
