Just Lost 4MPG in a tune up
Old Jan 10, 2013 | 04:38 PM
Pete-87-22r's Avatar
I'm sure this has been posted several times before but I didn't find much that applied to me when I googled it. My truck is an 87 Xtracab, 22r carb, 4x4, completely stock, manual transmission and I recently put on a cab high shell. When I first bought my truck I was getting about 22MPG, It had a rough idle, and idled at around 800rpm. I was expecting to get a little better mileage once I smoothed out the idle and got it down to 700rpm. I recently went through and got the timing back to 0* (it was retarded about 5* before), the idle down to 700 and replaced my #4 plug wire because the contact was a little corroded for some reason. Now im getting 16mpg. I still got 20mpg after I put on the shell, all I can think of is maybe the AAP diaphram or something, maybe the valves need to be adjusted? Also I'm in Southern California and my truck was brought down from Colorado within the last year and its got the HAC valve, pretty sure it's not doing anything now but this is my first truck and I'm driving 40 miles a day for school, so 16mpg aint good.
Thanks, Pete
Old Jan 10, 2013 | 10:36 PM
xXbrutalXcoreXx's Avatar
Check to see if the diaphragm on the acceleration pump is still good. I just replaced mine after finding out that every time I gave it gas, fuel was leaking out past the diaphragm. Check this link for some useful info: http://www.bluebassdesign.com/boonin/carb_faq/
Old Jan 11, 2013 | 08:28 AM
Gamefreakgc's Avatar
Wrong engine
Old Jan 11, 2013 | 08:48 AM
snobdds's Avatar
Originally Posted by Gamefreakgc
First off, the shell adds weight and possibly some wind drag, so that will make your MPG drop. Whether it's 4 MPG drop's worth or not is still to be figured out.
When you adjusted timing did you jump the terminals TE1 and E1? The FSM states you should do it first and adjust to *5 degrees. See steps 5 and 6 below:
http://personal.utulsa.edu/~nathan-b.../5distribu.pdf.
If you did jump the terminal and adjust to 0, it needs to go back to 5. Unjumped, it should be between 10-14.
A 22r is a lot different than a 22re. This^^ does not apply to a 22r.
Old Jan 11, 2013 | 08:51 AM
Ahh, my bad. I missed that part!
Old Jan 11, 2013 | 04:52 PM
Dug into the vacuum lines today after school and found the AAP is dry but there was quite a bit of gas in the top hoses of the HAC. Checked my idle speed again and it was back to 850rpm??? Corrected that, gonna see how it does now. Think maybe I forgot to reajust it after doing the timing. Would the idle speed affect the mileage all that much?
Old Jan 11, 2013 | 05:58 PM
oldblue's Avatar
what kind of plugs did you use? sounds stupid, but it can make a difference
Old Jan 11, 2013 | 08:57 PM
Spark plugs or the vacuum plugs? I dont know about the spark plugs but they're the same as when I got it and they're fine. For vacuum plugs I used an earplug for the big line from the air cleaner and im using nails wrapped in electrical tape for the little 1/8" ones. I guess thats not ideal but I figured it pluged em pretty good.
Old Jan 12, 2013 | 11:14 AM
stock87's Avatar
Did you unplug the vacuum advance when you set the timing? Base timing is supposed to be 0° with the lines unplugged and capped. It's supposed to advance to 12° when you plug it back in. If you set it without unplugging the lines...
Old Jan 12, 2013 | 01:14 PM
I did the timing right. Been adjustin the valves today and ran into a bit of a headache. The #4 cylinder had low compression (120 while the rest were 145), the valves were clicking on the same cylinder but not bad, found out they were a little tight, so I adjusted them to spec (.008 intake .012 exaust). Started the engine up again and they started clicking really loud, adjusted them again, same thing. Tightened them back to where they were before, and now theyre not as loud but still noticable. The engine was warmed up every time before I adjusted them. My engine only has 111000 miles so I'm lost.
ladybugRC
458
Aug 21, 2020 10:41 AM
the_supernerd
Oct 1, 2015 09:20 PM
voiddweller
Sep 28, 2015 11:21 PM
Scotttekoch
Sep 28, 2015 10:30 PM
JPV
Sep 28, 2015 03:15 PM
