Just finished painting my rims Check em out!!
Old Jul 27, 2009 | 08:27 PM
mikepr55's Avatar
are you going to paint all but the rivets I think that would be bitchin
Old Jul 27, 2009 | 09:43 PM
Boxer54's Avatar
I'm actually thinking about doing that
Old Jul 29, 2009 | 03:44 PM
Patty Robs's Avatar
new here...
i have these rims on my 93 yota with a 4" lift. i have dick cepek 33x12.5's mounted on them. what is the make of this rim if anyone knows?
Old Jul 29, 2009 | 08:40 PM
Boxer54's Avatar
Alright so we have a little problem...actually a big one!
So i went to go wash my tuck and started by wetting the dirt that i had gotten on my rims off, but as i was rinsing them i noticed that the water running off was black. So i bent down to go look at the rims and ran my finger around the edge and the black paint began to come off! practically all the way to the primer! I mean it came off like powder as if it had never really set in..and i had painted them 7 days ago!! And i followed the directions exactly!
Then i knew my friend had painted his rims with engine block paint. So i decided to try this with my spare tire and i found out that this works so much better!!! The rim was dry to the touch in 30 minutes and i was even able to run my finger along it to see if i would get the same result as before but nope! So now im going to sand all the wheels down again and spray them with Rustoleum Engine Block paint..Ill post more UPDATED pics once i finish
Old Jul 29, 2009 | 10:13 PM
  #25
Fink's Avatar
That sucks dude, never heard of that happening before.
Good luck with the new stuff, look forward to the pics.
Fink
Old Jul 29, 2009 | 10:16 PM
  #26
Boxer54's Avatar
I noticed it after i finished painting and figured i would just let them dry but the stayed like that, it was weird like all the pigment came off
Old Jul 30, 2009 | 12:00 AM
  #27
peow130's Avatar
Wow, that sucks man.
When i did my rims with actual rim paint i never had that happen lol. It's like you painted with watercolor paints...
Old Jul 30, 2009 | 09:57 AM
  #28
eighty5yota's Avatar
go solid black in the middle and do a silver lip ... easier and imho looks a bit better
Old Jul 30, 2009 | 11:01 AM
  #29
yota_mota's Avatar
I would contact the paint company and say WTF?
Old Jul 30, 2009 | 03:59 PM
  #30
Tragic Drive's Avatar
strip all the clear off and reseal them. That rim design looks great in all aluminum.
Old Jul 30, 2009 | 04:16 PM
  #31
Fink's Avatar
This would be my choice too.
I had to go back and look at the original pics to see why you were painting them in the first place.
Fink
Old Jul 30, 2009 | 11:10 PM
  #32
Boxer54's Avatar
Seriously last time i use Duplicolor! lol..Well sanded down the 2 front wheels today paint tomorrow..i will post pics on saturday most likely
Old Jul 31, 2009 | 07:56 AM
  #33
dropzone's Avatar
Fossilized
This is after all of the sanding and cleaning of the rim and after i taped off the rivets as part of my design idea
To me it doesn't look like you did enough prep as far as trying to get the clear coat off.
use something like alcohol or mineral spirits to clean the rims before paint and let it air dry for awhile/. the pigment coming up might have been the result of some residual oil or moisture on the rims. Or incomplete shaking of the Rattle can-propellant was separating in the paint...Shake the can harder/longer
I had a similar issue painting a white steel rim for my spare...took the time to prep it right the second time and it looked a lot better--even a year later it is holding up
light coats with lots of drying time between coats.
Old Jul 31, 2009 | 09:52 PM
  #34
Boxer54's Avatar
I must admit i didn't take the prep time care that i took when i painted my skid plate..i think it was the moisture because as soon as i laid down my first coat it started pour. However i just finished two rims today and will be posting updated pics soon.
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
chukarhunt
Dec 8, 2019 11:39 AM
Yotoder865
Jul 9, 2015 07:51 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
