just fail smog test in cali.........
Old Jul 3, 2010 | 06:39 PM
Teuf's Avatar
Ah hah, and what happens as its being driven.
Old Jul 4, 2010 | 09:59 AM
norcal707's Avatar
the truck runs good on the highway, on the video, I am pushing and holding the pedal down and as you can see the rpms goes up and down. it sure look like I am doing it but I am not. however, I found out the PAIR reed valve makes a clicking noise and when i take off the little vacuum hose, it stop right away.
Old Jul 4, 2010 | 10:09 AM
boxer.fan's Avatar
Could this be a rev limiter issue??? Just wondering if this could also have an ignition issue. I beleive where your at in Willits, which is NorCal, the smog test will consist of 2 idle speed test which is where the tech only idles the engine and not on a roller system, dyno machine, like here in SoCal.
Hey Citrus, I also have my smog licence, here in SoCal we have to have the Advanced Emmisions licence. Dont remember if Sacramento requires the Advanced or just Basic.
Old Jul 4, 2010 | 10:11 AM
CitrusTheDragon's Avatar
I am still in school getting mine and I will be getting the advanced
Old Jul 4, 2010 | 10:24 AM
  #25
norcal707's Avatar
yeah the shop doesnt have the roller system....
Old Jul 4, 2010 | 10:51 AM
  #26
The smog dino???? Ok now I am lost, u sure u are getting a smog check
Old Jul 4, 2010 | 11:30 AM
  #27
Keith B.'s Avatar
Definitely fix the problem with the vacuum, throttle, etc BEFORE you take it for another smog test anywhere.
Old Jul 4, 2010 | 12:47 PM
  #28
Teuf's Avatar
I don't think he is moving his foot to make it fluctuate, there is a prob some where. Stay with us there is an answer somewhere.
Necessity is the Mother of all inventions.
Old Jul 4, 2010 | 08:22 PM
  #29
whorider's Avatar
It depends on what county you live in. Some don't require a dyno. As a smog tech you should know this. Just enter the VIN and the computer tells you which test is required, dyno (enhanced) or static (basic). Some counties only require a smog when you change ownership.
To the original post.
Have you ohm tested the TPS? Checked its sweep? That would be a good place to start. Check out the FSM for specs and which terminals to check.
Old Jul 4, 2010 | 09:21 PM
  #30
norcal707's Avatar
I have to do the smog to put it under my name.
Old Jul 5, 2010 | 09:03 AM
  #31
Don't have my full certs yet still in school
Old Jul 5, 2010 | 09:41 AM
  #32
bio6040's Avatar
Smog problem too!
I took my 86 4runner to a smog station in socal on Friday and the tech said my timing was advanced to high so when he went to adjust it he jumped the larger yellow test plug (the one with 3 wires in the back) not the smaller one (the one with 2 wires in the back) and the engine died and now it will not start. He replaced the coil and cap and rotor. Now he is saying it is a different problem and it must have been pre existing! Does anyone have any idea what he could have done? Any help please. Sorry to thread on someone else's thread!
Old Jul 5, 2010 | 10:55 AM
  #33
norcal707's Avatar
no problem bio6040
Old Jul 5, 2010 | 11:15 AM
  #34
norcal707's Avatar
ok!!!!!! update: I have put a new thermostat, check all the hoses, and took it for a cruise....I was driving on the road and ones the rpms come to 2500, it does the same thing, like that engine wants to die. I also found that this valve makes this loud clicking noise, as soon I take the small vacuum hose, it stop.
http://i966.photobucket.com/albums/a...0705-11501.jpg
Old Jul 5, 2010 | 11:26 AM
  #35
norcal707's Avatar
and here my 4runner...just to show you all my fuss is about.....
Old Jul 5, 2010 | 12:41 PM
  #36
whorider's Avatar
If you don't feel up to ohm testing your TPS at least disconnect it and try it.
Old Jul 5, 2010 | 01:03 PM
  #37
norcal707's Avatar
i dont have anything to test it....I will disconnect it and see what happend...
Old Jul 5, 2010 | 02:04 PM
  #38
norcal707's Avatar
TPS=throttle position sensor right?.....this little black sensor
Old Jul 5, 2010 | 02:23 PM
  #39
norcal707's Avatar
BINGO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I disconnect this sensor and rev up the engine to 2500 rpms, hold it for 90 seconds and no problem what so ever....I am reading on my manual and is telling me I have to test the ohm but I dont have one.... I guest I have to wait for payday to buy one.....THANK YOU WHORIDER for suggesting this....
Old Jul 5, 2010 | 02:48 PM
  #40
helidriver's Avatar
When I bought my truck in SoCal it was explained to me that it was the sellers responsibility to make it pass smog before the sale....
