Intermittent Code 5 1986 22RE
Old Jun 13, 2016 | 02:51 PM
GeoRoss's Avatar
Hello all,
I have an intermittent code 5 come up in my 1986 4Runner 5sp with a 22RE. It has only happened twice, both times on the highway when going up steep grades, 4th gear 3700rpm sort of hills and nearly floored. The light will come on for 30 seconds up to a couple of minutes and then go away. The first time was in December while driving it to AZ fro CA when I bought it. It happened twice today climbing up to Flagstaff.
I'm out of town and it is mostly downhill going home so I won't fret it. I'll change out the O2 sensor when I get home. Hopefully that is all it is, but I'm not sure.
Question 1: Is the sensor back to normal once the light goes out? I'd hate to be running lean/rich all of the time. I think everything is back to normal once the CEL goes out.
Question 2: The 4Runner runs great I got 25 mpg today driving 70 mph with the AC running. If the o2 sensor doesn't fix it, I'm thinking that I'm running lean on these steep grades. My list of stuff to check would be in the fuel delivery side. Other than the pump and injectors any other diagnostics I should run? I don't like throwing parts at a problem.
Thanks for any feedback. Flagstaff is so much nicer than Tucson this time of year.
Old Jun 17, 2016 | 08:47 AM
GeoRoss's Avatar
The CEL didn't not come back on the rest of the trip back home. I was getting 20+ mpg grieving in the mountains with the AC on.
I'll check the O2 sensor, but I really don't think that is it.
Old Apr 6, 2017 | 07:26 PM
helidriver's Avatar
Fixed??
Im tracking a Code 5 issue now...
Old Apr 8, 2017 | 11:53 AM
GeoRoss's Avatar
Mine has not come back.
Old Apr 9, 2017 | 04:17 AM
Terrys87's Avatar
On intermittent codes, the most error from my experience is a vacuum leak some where. Cracked hoses, one not hooked up somewhere...
4x4-runner
Apr 23, 2018 09:35 AM
gsp4life
Jul 18, 2016 08:35 PM
Ifoundyoda
Jun 10, 2016 07:48 AM
Irishman03
Jun 3, 2016 08:59 AM
geoduke
May 18, 2016 04:18 AM
