interchangable tranny ?
Old May 10, 2007 | 09:03 PM
86toysr5's Avatar
this guy i work with i give him a ride home sometimes...
his roommate has a 4runner that has a bad tranny
i believe it is a 94 or 95 with the v6 and 4x4
my dad has a 88 or 89 4runner at his bosses from with a hg prob but good tranny
my mom needs a new vehicle
both v6s and 4x4s so do you think the trannys would swap?
Old May 10, 2007 | 09:07 PM
MudHippy's Avatar
Sure, might even be the same. But, what ever bolts to one V6 of those years will bolt to another 3VZE(the V6 available then).
Old May 11, 2007 | 05:24 AM
WFO's Avatar
WFO
Check out how the speedometer works. I belive pre 92 was cable driven while 92 and up was electronic
Old May 11, 2007 | 05:46 AM
86toysr5's Avatar
speedometers are over rated lol
Old May 11, 2007 | 06:15 AM
TNRabbit's Avatar
Depends if it is '95. Halfway thru the year they started putting the 3.4 liter engine in the Runner/Tacoma.
Old May 11, 2007 | 06:32 AM
DeathCougar's Avatar
Manual or Automatic?>
If its manual, it shouldn't be any problem. If its auto, it may not work due to wiring/plug/electronic changes through the years.
The speeedo drive gear can be switched out from year to year, so just reuse whatever gear thats currently in it. btw, if its an actual 95, you wont have to change it since they reverted back to cable drive for 95. Only 92-94 4Runners were electronic drive speedos.
Old May 11, 2007 | 01:52 PM
86toysr5's Avatar
good info to no
ladybugRC
458
Aug 21, 2020 10:41 AM
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
Davebarbier
Nov 3, 2015 03:28 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
