installed hids
Old Jan 20, 2011 | 12:22 PM
toykidd's Avatar
looks good consider those for my rig i like them a lot
Old Jan 20, 2011 | 01:15 PM
shaeff's Avatar
Originally Posted by justin_4runner
today my hid kits i had bought off ebay came in, got housing and hid bulbs 6000k i went with dont like it too blue, hers some before and after pics,
before hid...http://i758.photobucket.com/albums/x...er/Lights1.jpg
http://i758.photobucket.com/albums/x...er/lights5.jpg
after
http://i758.photobucket.com/albums/x...er/lights4.jpg
high beams
http://i758.photobucket.com/albums/x...er/lights3.jpg
low beams
While the cutoff is relatively "sharp" (and that's debatable) the beam spread looks terrible. One of the classic examples of why NOT to put HIDs into halogen housings.
For what it's worth, I've done both- the PnP style kit in Hella E-code housings, and a proper retrofit. I used to swear by my PnP kit, but the fact is that they just suck no matter how you look at it. I guess you could say I "saw the light" and removed the PnP kit and went with a proper rewired halogen setup with dual beams (highs stay on with lows) and the output is much better than the PnP HID kit. Better spread, better cutoff, better all around.
If you're not doing a proper OEM style retrofit, just don't bother. A good halogen setup will be better, more reliable, have better output and a better cutoff.
Originally Posted by MaK92-4RnR
I should post up my new 3k HIDs. lol
Please do.
Old Jan 20, 2011 | 01:31 PM
MaK92-4RnR's Avatar
I haven't done a cut off picture yet, but heres the look. i'll post the specs of the kit, color, wattage, and where i got them when in my own thread. note: these are cell phone quality
Old Jan 20, 2011 | 01:58 PM
richf's Avatar
How do you install these inside of a glass sealed beam? It looks like a easy mod but I don't get that part.
Old Jan 20, 2011 | 02:01 PM
  #25
MaK92-4RnR's Avatar
what do you mean?
Old Jan 20, 2011 | 02:10 PM
  #26
xxxtreme22r's Avatar
these are conversion housings, not OEM style sealed beams. I think I confused him on not running hid in a plastic housing. Some conversion housings are plastic and some are glass. HID should only be used in glass.
Old Jan 20, 2011 | 02:18 PM
  #27
richf's Avatar
The lamps my truck uses right now are all one piece everything is sealed together. I can not remove the light bulb. When I got to replace them I have to replace the whole lamp not just the bulb. FYI I don't anything about this kind of stuff.
Old Jan 20, 2011 | 02:26 PM
  #28
MaK92-4RnR's Avatar
on 2nd gen 4Runners, its held on by a circular clip, spin it off, pull the bulb out, put the HID in, reattach the clip, and hook up the ballast... you're good to go.
Old Jan 20, 2011 | 02:33 PM
  #29
richf's Avatar
I have a 85 -1st gen runner .
Old Jan 20, 2011 | 02:51 PM
  #30
MaK92-4RnR's Avatar
yeah i have no idea about yours
Old Jan 20, 2011 | 03:19 PM
  #31
drmix's Avatar
You need a conversion kit like this that converts it to a H4 bulb. I am gonna be doing it once I get my yota back on the road but I hear its way better
http://cgi.ebay.com/ebaymotors/82-95...item3ef4015edd
Old Jan 20, 2011 | 03:24 PM
  #32
richf's Avatar
Ya I read in a nother thread today that you shouldn't use that lamp for the HID conversion. Something about the cut off and blinding over people and you wont be able to adjust them. I wonder if the light put out is better than what I have now?
Old Jan 20, 2011 | 03:30 PM
  #33
drmix's Avatar
Yeah you shouldnt run them with hids but it im sure if you bought those with some nice bulbs and upgraded your wiring you will be set. Ill try and find the pics from someone else who upgraded to those
Old Jan 20, 2011 | 03:46 PM
  #34
drmix's Avatar
Heres a thread that has some pics
http://www.toyotanation.com/forum/sh...d.php?t=361680
Old Jan 20, 2011 | 03:58 PM
  #35
Authority's Avatar
you have to buy some new housings like drmix has pointed out in order to change the bulb.
Old Jan 20, 2011 | 04:38 PM
  #36
richf's Avatar
Thanks for the link I think I will go with those. Do you think those will those plug into my existing wiring?
Old Jan 20, 2011 | 07:10 PM
  #37
drmix's Avatar
Yeah im pretty sure the wiring is the same but its better to upgrade the wiring to something thicker especially if you want to upgrade to some more powerful bulbs. Ive heard good things about the osram nightbreakers which is what ill probably be going with
nvdesertrunner
May 11, 2020 08:18 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
punks_is_4x4
Aug 21, 2015 01:35 PM
Edionne13
Jul 9, 2015 01:59 PM
