Im not getting very good MPG
Old May 20, 2007 | 04:23 PM
joehill's Avatar
right now I am getting 10 city and 12 highway. it should be getting about 17 and 20. I dont have any idea why. the engine is very smooth, the RPM dont run high. no indicator lights are on. its an AT that is shifting fine(just had the fluid flushed.) I would say i am taking it easy on the gas peddle.l i think the tires are 31 inches.
an example: i just drove it des moines from MPLS this weekend. its about 240 mile drive and I couldnt make it on one tank.
I do need to get it fixed with gas prices being what they are.
What could it be?
Old May 20, 2007 | 04:25 PM
ChickenLover's Avatar
There is no need to post this thread twice.
Old May 20, 2007 | 04:32 PM
olharleyman's Avatar
try the fuel filter and air filter and 02 sensor also clean the injectors. these are the most common issues.
Old May 20, 2007 | 05:10 PM
AH64ID's Avatar
I recommend deleting one of your posts, only need one per topic.
Old May 20, 2007 | 05:12 PM
joehill's Avatar
if I only knew how to.
Old May 20, 2007 | 05:43 PM
TNRabbit's Avatar
I'd try O2 sensor first. When's the last time you changed your air filter?
Also, I'm guessing you have the 3veezee as not four cylinder could EVER get mileage THAT bad...
Old May 20, 2007 | 05:45 PM
AH64ID's Avatar
edit, then delete....
Old May 20, 2007 | 05:46 PM
AH64ID's Avatar
yeah its a v6, check his sig, and there is a ton more info in his other thread...
Old May 20, 2007 | 05:47 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
if only that was still true. i havent asked anyone else but the normal delete option disappeared for me several weeks ago and i can't find it. I PMed Corey about it and he never responded
EDIT: upon searching, we in fact can't delete posts or threads at the moment. https://www.yotatech.com/forums/f92/deleting-threads-posts-115250/
Old May 20, 2007 | 05:49 PM
AH64ID's Avatar
oh wow, havent deleted a post in a while, and yep its not there????
Old May 20, 2007 | 10:46 PM
notanymore's Avatar
trust me its very possible for the 4banger to get that mileage
but back on topic i would start with your 02 sensor
Old May 20, 2007 | 11:12 PM
91muddog's Avatar
my 4cyl get 10mpg on a good day...
otherwise i would mind the v64runner alost more.
4cyl just need some lovin though!
Old May 20, 2007 | 11:18 PM
Spanky's Avatar
What could it be?
you know what would be good?? is to post what you are driving! your sig would be a great place.
Old May 20, 2007 | 11:28 PM
Spanky's Avatar
oh wow, i just noticed that this thread is posted twice... so should i respond in the other thread with this message too? and probably my last post too right??
Old May 20, 2007 | 11:29 PM
Spanky's Avatar
haha.. dont worry, cause i did it in both
Old May 20, 2007 | 11:37 PM
SwampThing's Avatar
My mileage got a little better after I replaced my cap rotor wires and plugs the other day. Runs a whole lot better now too. 20mpg was good, but 22 is even better. Yeah, I'm a happy camper now.
coffey50
Jul 28, 2015 10:55 AM
Michael oaks
Jul 27, 2015 11:47 AM
PlayAwhile
Jul 20, 2015 11:36 AM
ryerye13
Jul 14, 2015 08:27 AM
Jnkml
Jul 6, 2015 01:20 PM
