Im having over heating in my 91 4runner 3l v6. what are possible problems?
Old Jul 29, 2009 | 04:43 PM
chaltig's Avatar
My 4runner is overheating pretty bad. i had the head gasket replace last year and just replaced the thermostat. It over heats, or says its over heating, when I'm stopped, but while driving it runs just fine? any suggestions?
Old Jul 29, 2009 | 04:46 PM
Jay351's Avatar
check your fan clutch...
Old Jul 31, 2009 | 09:38 PM
chaltig's Avatar
its good
Old Jul 31, 2009 | 10:24 PM
Jay351's Avatar
Is your water pump good, is your coolant old and cruddy?
Do you have a fan shroud?
You sure you put the right thermostat in??? What kind?
Old Jul 31, 2009 | 11:11 PM
Tofer's Avatar
Sponsor
Old Aug 1, 2009 | 12:11 AM
mick cassidy's Avatar
is your idle @ 800-1000 rpm , also try to flush your cooling system i yse white vinegar it breake up water deposits you need to learn the back flush technique disconnect the top rad hose and have the garden hose to the intake of the rad. truck running takes about 20 mins then drain and mix 50 50 coolant if your still having heating issues check timing , check the rad if you see crud in the rad. try to switch to a alum one fan and shroud will cause problems thats it for a cooling system its pretty basic
Old Aug 4, 2009 | 05:47 AM
chaltig's Avatar
yeah it was a bad rad and thermostat.
alexcarey
Oct 14, 2015 06:05 PM
dzldust
7
Oct 6, 2015 05:39 AM
Flightguy
Oct 2, 2015 05:34 PM
Jdgarrison
Oct 1, 2015 05:22 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
