ignition
Old Oct 25, 2017 | 02:55 PM
George O.'s Avatar
ignition
Car does not start. Key turns, but it seems like the spring broke. How do I replace that?
Old Oct 25, 2017 | 10:28 PM
wyoming9's Avatar
Red face
From what you describe it sounds like the electrical part of the ignition switch broke .
Depending what year pull the covers off to access the switch.
Remove the lock cylinder (key turned to accessory push the pin and pull the cylinder out.
there should be a screw holding the electrical switch in.
Figure out if that is the problem
This is off the Top of my head I may have missed a step!!
Old Oct 26, 2017 | 08:48 AM
George O.'s Avatar
I pulled out the lock cylinder and the ignition switch and found that the rod inside the bracket had broken. I couldn't find an after market part, had to order a new bracket from the dealer. I'll pick it up tomorrow and let you know if it works.
Old Oct 26, 2017 | 08:58 AM
scope103's Avatar
Take pictures, please.
shafner30
Nov 16, 2022 07:37 AM
wrenchtech
50
Sep 8, 2019 01:18 AM
Mntbiker
Nov 29, 2017 01:16 PM
dillonholden
Oct 28, 2017 06:37 AM
AmirK
Oct 25, 2017 05:23 AM
