Ifs box dead spot.
Old May 30, 2019 | 02:27 PM
crustyredyota's Avatar
Ifs box dead spot.
Hello,
Just swapped in an early style ifs box and it is hard to turn at idle or at low speed. When I started the vehicle this morning I had zero power steering until I drove it for a bit. The truck is hard to turn at first then easier to turn as it gets toward lock in either direction
I bled the system a few times and have not gotten any different results. Does this sound like a worn out box or another issue ?
Old May 30, 2019 | 03:19 PM
scope103's Avatar
Welcome to YotaTech.
By "ifs [Independent Front Suspension] box" I'm going to guess you mean the Power Steering Gear Housing. My guess is that the adjusting screw is too tight. You need to adjust freeplay. http://web.archive.org/web/201310211.../3onvehicl.pdf
Let me suggest you learn how to set your "signature." That's the best place to put your make/model/year/engine/transmission/body style information, so you won't have to keep re-typing it. Yes, all of that is important, if you want to get usable advice.
Old May 30, 2019 | 05:56 PM
The adjustment screw is already backed out pretty far. I’m experienced at most things mechanical but have never had a steering box go bad.
humboldtcorrado
Aug 26, 2013 08:02 PM
My99
Jul 12, 2012 06:21 PM
reezie
Dec 28, 2007 10:17 AM
Stegall984R
Nov 28, 2005 03:39 PM
