Idler Arm Brace Dimensions
Old Jul 10, 2009 | 02:21 PM
JAV4's Avatar
6 months back I purchased a Downey Idler arm brace but held out installing it. I have purchased the autozone idler arm recommended by SDORi and intend on ordering his brass bushings for that model. The issue is that the Downey brace does not necessarily cradle the idler arm tightly, as it would an oem arm. There is a gap at the tab (widest part) along the arm. Any suggestions? Will this defeat the purpose of installing the brace? The truck does get used for rock crawling or anything "extreme". This will be the third idler arm in 9 years. Appreciate the advise as always!
'92 4runner
31x10.5 BFG ATs
SDORI BJ Spacers w/ stock torsion bars.
Old Jul 10, 2009 | 02:24 PM
JAV4's Avatar
Correction
The vehicle does not get used for rock crawling. It is an occassional daily driver.
Old Jul 10, 2009 | 04:17 PM
BigBluePile's Avatar
Hmmmmm, well, I know that on my brace I just tightened the bolts up to "sandwich" the arm for a nice snug fit.
Old Jul 11, 2009 | 05:05 PM
JAV4's Avatar
Sandwiching the tabs to bend them in still leaves a gap. I'm thinking of having extra material welded before I install it.
Old Jul 11, 2009 | 05:08 PM
Matt16's Avatar
The brace is intended to prevent the arm from folding up- side to side movement is not important.
Old Jul 11, 2009 | 08:36 PM
Jay351's Avatar
I simply tightend the bolts enough to bend the brace around the idler. It makes removal impossible without a good bench vise but its worth it.
also. I would change out the bolts they give you, they are only grade three, I already broke two.
Old Jul 12, 2009 | 12:01 PM
JAV4's Avatar
Thanks.
Old Jul 13, 2009 | 04:54 AM
Kaptain's Avatar
x2 - you will be fine running this.
Old Jul 16, 2009 | 09:22 AM
JAV4's Avatar
Looks like I'll go that route. I still need to order the SDORI brass bushings before I proceed. I sprung for the NAPA pitman arm that will go on at the same time.
Thanks for the suggestions and advice
ladybugRC
458
Aug 21, 2020 10:41 AM
ktm192k
Oct 1, 2015 08:47 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
tylermx71
Sep 29, 2015 08:49 PM
crash813
Sep 27, 2015 07:15 AM
