Idle problem on 22RE...
Old Dec 19, 2009 | 10:15 PM
JDMHondaGuy's Avatar
Ok, so I've been doing some work on my truck ('90 pickup 5speed 22RE) since I got it and now since put a new thermostat in, the truck actually warms up to proper temperature. I also replaced the TPS cuz the old one got bumped in the process of changing the T-stat and the 20 year old brittle plastic snapped with little effort. So, getting more to the point after all that and proper adjustment (I think) of TPS the truck will idle just fine till it warms to proper temperature then it will die... not all the time but most of the time... So I'm at a loss of what to try.... All input appreciated!!! THANKS!!!
Old Dec 20, 2009 | 07:30 AM
yoterr's Avatar
ide start with the cold start injector, it adds extra fuel to the mix when your engine's cold
Old Dec 20, 2009 | 08:10 PM
ok, how dose that make sense? I dont have cold idle problems, I have warm idle problems.
Old Dec 20, 2009 | 09:04 PM
abecedarian's Avatar
If you are 100% confident the TPS is proper, set the idle and timing with the engine warmed up, not cold.
Then troubleshoot the cold engine problems.
Old Dec 20, 2009 | 09:40 PM
ok, I will double check the TPS setting and mess with the IAC valve and see what I can figure out.
BTW, I have no Cold engine problems!... lol... Again, its only warm idle...
Charecter1
Nov 6, 2023 10:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
v_man
Jul 23, 2015 04:01 PM
kyletbert
Jul 17, 2015 11:39 AM
Jnkml
Jul 6, 2015 01:20 PM
