idle problem with 22re
Old Feb 25, 2009 | 09:18 AM
kawasakimoto_7's Avatar
alright well i have a problem with my 22re (206,600 miles) whenever im sitting at a light or something my truck sits a rattles everything in the truck...like a lot but once i get going it stops or when i have my foot on the gas a little it stops too...what could the problem be?
-thanks
Old Feb 25, 2009 | 09:30 AM
abecedarian's Avatar
checked your spark plugs, distributor cap, wires and coil?
how are your engine mounts?
Old Feb 25, 2009 | 09:33 AM
the engine mounts are good and everything but i guess it might be the plugs and whatnot cause i sunk my engine underwater like a month or two ago...so i should probally pull and clean those or something.
Old Feb 25, 2009 | 11:10 AM
Kiroshu's Avatar
Uh yea!
Old Feb 25, 2009 | 11:19 AM
chris1rb's Avatar
i have the same problem and replaced everything u listed, my uncle is a mechanic and has his own shop, www.rosevillerodandcustom.com but anyways he went over it and the 4th cylinder on mine is running rich and he thinks the injector is bad and i have a really rough idle but once u give it power it smooths out so sounds like an injector
Old Feb 25, 2009 | 11:23 AM
toyota4x4907's Avatar
Try upping the idle just a smidgen, that might temporarily fix it if it bothers you.
replace the air filter as well.
Old Feb 25, 2009 | 12:13 PM
yeah im going to go through and probally change everything cause my truck is starting to overheat too but thats probally radiator fluid that i need to change
Old Feb 25, 2009 | 01:28 PM
if you're low on coolant, that can affect the idle quality on a 22re. also, thermostat rating should be 195.
...just a thought.
Charecter1
Nov 6, 2023 10:08 AM
jbv808
Aug 6, 2021 04:47 PM
Eggslinger
Jun 8, 2019 03:32 PM
steve miller
Oct 10, 2015 01:40 AM
Jnkml
Jul 6, 2015 01:20 PM
