I want a tach and gear indicator light on my dash.
Old Aug 15, 2008 | 08:59 PM
loquito's Avatar
So I have a 1991 v6 with an Auto trans with the shifter on the column. My instrument gauge has the large speedo and no tach.
I got hold of an sr5 instrument cluster but to use it I will not have the gear selector lights.
How did the 91 automatic trucks with the shifter on the column show the gear shift indicator lights.
Was there such a truck with an auto trans, shifter on the column and a tach, as well as gear shift indicator light on the dash?
Thanks
Old Aug 16, 2008 | 03:34 AM
Flash319's Avatar
I don't think pre 95 trucks had shift on the column. All 4runners and trucks I have seen where floor mounted with the console indicator. The cluster is almost plug and play.
Old Aug 16, 2008 | 06:19 AM
ozziesironmanoffroad's Avatar
x2 on being plug and play. if its up on the column, then someone did a retrofit... thats my guess...
Old Aug 16, 2008 | 06:22 AM
Belize Off Road Team's Avatar
To get the gears to show on the dash you will have to retro fit/ custom wire in some indicators.
Old Aug 16, 2008 | 09:28 AM
88wildrunner's Avatar
the older 2wd's had a column shifter. as for a shift indicator light youll need to buy an aftermarket tach to put on your dash. i have one it was pretty easy to install, i dont really pay attention to the light though its just for looks i guess. ill post a pic of it later or there may be one in my build thread
Old Aug 16, 2008 | 02:15 PM
abecedarian's Avatar
@ loquito: I've got a 91 column shift, but no tach on the cluster. I'll post a photo as soon as I get the truck back home if you'd like, but my cluster is probably the same as yours.
-offtopic: good luck finding a body lift for any older column shift since the shift linkage passes through the firewall next to the steering shaft.
Old Aug 16, 2008 | 04:36 PM
loquito's Avatar
Yes a photo would be cool.
smthwsn357
May 1, 2024 07:28 AM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
gary4runner
Sep 24, 2015 12:53 AM
shisha1999
Jul 13, 2015 11:09 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
