I need to know if I messed up on timing removal.
Old Dec 31, 2015 | 12:32 PM
d-wood's Avatar
After taking out my distributor. I went to take off my top camshaft bolt off and didn't know I had to wedge so it wouldn't turn.
When I turned it my crankshaft pulley moved counterclockwise about a 1/4 turn. I moved everything back but didn't know if I'm screwed.
Old Dec 31, 2015 | 03:49 PM
854x4's Avatar
When you moved the camshaft bolt you also turned the cam and crank gear together so as long as the chain didn't skip teeth on the gear you are fine even if it did its not that hard to line up. What are you doing? Head gasket? Timing cover?
Old Dec 31, 2015 | 04:06 PM
d-wood's Avatar
Thanks for the reply.
Timing chain replacement. My guides are broke. I scooped them out of the oil pan today.
I had my camshaft zip tied when I I turned it so everything didn't move in sequence.
I then stabbed my distributor back in and turned my crank over some revolutions to see what it looked like. Seems close but idk. I guess I'm gonna find some kind of tool too remove it.
Old Dec 31, 2015 | 04:41 PM
854x4's Avatar
If your pulling the cover then don't worry about being in time right now just get it close and triple check everything when you put it back together. As far as breaking the cam bolt loose I've always used an impact gun but if that's not an option there's a hole in the cam right behind the gear that you put a punch in and hold it while you put a breaker bar on the bolt.
Old Dec 31, 2015 | 05:57 PM
d-wood's Avatar
Thanks for the tips. I think my biggest concern was if the top will be perfectly in sink with the bottom along with my distributor(cause the rotor button ain't perfect I'm sure, since I moved it after removing it. Does it matter if my dizzy lines up perfectly from where I took it out? I do understand what your saying though. Thank you.
Old Dec 31, 2015 | 07:18 PM
854x4's Avatar
After putting new gears and chain on and making sure they are lined up at TDC. When you go to stab the distributor I usually put the hold down bolt dead center and line the rotor up so that when the distributor is fully seated its pointed at number one cylinder on the cap. This usually gets your ignition timing close. Look for the FSM on this forum and it will tell you what clock to put it at. As long as you don't turn the crank or cam one full revolution while you have the chain off you will be fine. Marking the distributor is not really needed if you follow the FSM. The worst that can happen with the distributor is it will be 180 degrees out. I don't think I've ever marked a distributor on these engines but then again I'm usually pulling the head.
Old Dec 31, 2015 | 07:24 PM
d-wood's Avatar
Will do. I appreciate it. Also what is the hold down bolt? Are you talking about the bolt that holds the dizzy or the whole shaft part of the dizzy. Thanks!
Old Jan 1, 2016 | 12:54 PM
854x4's Avatar
For hold down bolt I mean the bolt that holds the distributorto the head (the one you loosen to adjust ignition timing).
Old Jan 1, 2016 | 08:42 PM
d-wood's Avatar
Thanks. I made another thread showing my progress. I'll add some more pics as I go. I'd do a video but I do t know how. Well I don't know how to post it on here.
Old Jan 2, 2016 | 12:17 PM
d-wood's Avatar
Here's an update of where I'm at. These are some pics of what my sprockets look like before the timing chain is put. Kinda a dry fit with my new sprocket.
Attached Thumbnails I need to know if I messed up on timing removal.-photo927.jpg   I need to know if I messed up on timing removal.-photo681.jpg   I need to know if I messed up on timing removal.-photo174.jpg   I need to know if I messed up on timing removal.-photo8.jpg
justdifferentials
Just Differentials
May 5, 2016 07:01 PM
d-wood
Jan 7, 2016 05:19 PM
4runninmuds
Dec 31, 2015 08:25 AM
Yotapower01
Dec 29, 2015 01:58 AM
Mason King
Dec 16, 2015 12:29 AM
