I have a 1993 Toyota pickup 3.0 4x4 an i want to beef her up
Old Apr 23, 2014 | 04:16 PM
  #61
Zach1993's Avatar
Originally Posted by thefishguy77
Might be an overdrive button? Is it an automatic? Just guessing.
yeah it is, what's that do?
Old Apr 23, 2014 | 04:17 PM
  #62
Zach1993's Avatar
ohh just to use while the truck isn't on?
Old Apr 23, 2014 | 04:32 PM
  #63
93Xtra-Cab's Avatar
https://www.yotatech.com/forums/f116...button-242434/
Old Apr 23, 2014 | 04:34 PM
  #64
thefishguy77's Avatar
No overdrive is for fuel economy. If your cruising down the freeway at 60 in overdrive or 5th gear and you shut it off it will effectively downshift the transmission. This is not designed to act as a down shift and abuse of it can cause long term wear and tear. But if your heavy with a load going down a road that has several small inclines. If the speed limit is 45 you might do better to turn off you overdrive so your not asking your transmission up shift and down shift a lot. Not sure how your rig drives I'm sure you'll figure out what your truck likes.
Old May 8, 2014 | 04:56 PM
  #65
Zach1993's Avatar
Iv recently noticed rust starting behind the back left wheel base where it curves to the bottom of the truck I don't know if you can picture that but I can take a picture if needed, what's the best way to fix it just cut it out an replace the metal
Old May 8, 2014 | 05:32 PM
  #66
If the rust is deep then cut it out. But if its just starting you probably could expose it grind it away fill it as needed and repaint. Just make sure you figure out why it's rusting. Is it salt from the roads? Crap getting packed in there from normal use? Or just buried it up to the axels one too many times. And just never pressure washed it out.
Old May 8, 2014 | 05:37 PM
  #67
Zach1993's Avatar
I just did pressure wash it, is that what did it?
Old May 8, 2014 | 05:48 PM
  #68
No one time pressure washing won't do it. Unless you were at bare metal already. That probably just exposed it.
Weidle
Jan 21, 2019 05:39 AM
Nathan_F
Aug 19, 2015 04:03 PM
Gamble_STi
Jun 27, 2015 07:54 PM
bprice0077
Jun 25, 2015 07:36 AM
nyk08trx
Jun 18, 2015 09:01 PM
