I don't know where these plugs go..help!
Old Apr 9, 2007 | 10:17 AM
Bill's Avatar
That blue plug might also plug into the back of the air-bypass thingy.
On the underside of the intake runners, on the back of where the airbypass tube connects there is an injector style connector.
It just doesn't look quite long enough to be the cold start(to me anyways).
Old Apr 9, 2007 | 11:21 AM
Joey's Avatar
No way slacker. I was confused as well, but being new here I didnt know if it was an inside joke. We wouldnt do that man.
Old Apr 9, 2007 | 07:00 PM
marty4runner's Avatar
I started it up!
So I started it. Fired right up. I decided to see what would happen without those plugs in. It worked. The idle was real rough. the major problem, though was the large amount of gasoline peeing from the lower passenger side (looks like). I'm not sure where it could be coming from. Nothing looks out of place. I think I'm just gonna tow it over to a Toyota mechanic and have them "put the finishing touches on it". There they can also check my EFI and computer stuff. What do you guys think?
Any ideas as to where the fuel could be coming from?
Old Apr 10, 2007 | 09:29 AM
Bill's Avatar
Did you reconnect the fuel return line from the fuel rail?
Old Apr 11, 2007 | 04:01 AM
  #25
Ok, that's what it was. Fuel return line. I adjusted the timing. The idle is still a little rough and I still can't find where those durn plugs go. I'm dropping it off this morning at a mechanic. They will figure out the plugs and double check my work and maybe clean my fuel injection. Thanks everyone for your help! I'll post when I find out what the plugs were.
Old Apr 15, 2007 | 05:38 AM
  #26
Brenjen's Avatar
Originally Posted by slacker
ohh .. ok . sorry then , I guess I miss understood .. I thought you guys were mocking me .
I'm glad I could help .
I certainly wasn't; you probably know a lot more about these Toyota's than I do. I was simply agreeing with you that the blue plug looks like the cold start injector. Most people aren't used to the Toyota having four cylinders but five injector plugs (or six cylinders & seven plugs etc.) & they may make the mistake of counting them & saying to themselves "yep, four. All of the injectors are plugged in" & forgetting about the csi.
Old Apr 17, 2007 | 07:47 AM
  #27
Just an update. I dropped the truck off at a local mechanic to figure out why it was running so rough. they found a couple of vacuum lines in the wrong places and a wire I had still not connected. Other than that, they said I did a pretty good job and now it runs great! It feels almost like a new engine. You can barely feel it idle. I can feel the upgraded cam a little, but I think that intake and a header would help things alot more. Anyway, thanks to all for the input!
This is the first thread I've started that has gone on to two pages! Yea!
Old Apr 17, 2007 | 03:18 PM
  #28
Brenjen's Avatar
so you never found out where the plugs go huh? odd
Old Apr 18, 2007 | 04:26 AM
  #29
The mechanic found out where one of them go. One went to the knock sensor (I thought I had found that and had a wire to it, but I guess that was something else). The other is still loose under the hood. I need to go back and ask them about it, but I'm assuming it doesen't need it as it's running great and gas mileage seems to be normal so far. We'll see. Oh, it was the yellow plug that went to the knock sensor.
Old Apr 18, 2007 | 08:51 AM
  #30
Brenjen's Avatar
Yeah, as others said. Are you 100% positive that you have the cold start injector plugged up? Because that sure is what that blue plug looks like.
Old Apr 20, 2007 | 05:26 AM
  #31
Well, if the cold start injector plug is facing forward just in front of the thermostat and just below and to the driver's side of the throttle body, then I have it plugged in. It looks like that's what it is in the manual. There is a blue plug there (I think it was blue.). Thanks!
Old Apr 20, 2007 | 12:04 PM
  #32
Yotaboy's Avatar
This is where my blue plug goes. Hope it helps
Old Apr 20, 2007 | 11:20 PM
  #33
Just Learning's Avatar
pretty good thread guys and slcker is that 22 long block from lc engineering--its the red color that caught my eye
Old Apr 22, 2007 | 03:54 PM
  #34
thanks yotaboy. I will check it when I get home. It would be great if that was it! We'll see...
Old Apr 23, 2007 | 06:56 AM
  #35
slacker's Avatar
Marty - good to see ya almost got er' beat .
nope ... my own engine I built . you can see more here
http://www.members.shaw.ca/slacker502/lowrider.htm
and here
http://www.members.shaw.ca/slacker502/technical.htm
I ended up selling it , and now am going 7M-GTE
Old Apr 23, 2007 | 08:26 AM
  #36
Brenjen's Avatar
I bet that's it. It's surely something to do with the fuel system. (I don't have the 22R or I'd have looked it over)
Old Apr 26, 2007 | 06:06 AM
  #37
Well Yotaman,
You win! That was it! Great picture, thanks alot! That plug is in the one spot I just couldn't see from any direction with everything back together. So what does that wire do? I wonder if I'll notice any difference. Thanks again.
Old Apr 26, 2007 | 08:39 AM
  #38
Yotaboy's Avatar
Glad I could help. That plug gave me trouble when I did my head job. Im not sure what it does but I know that coolant runs through that valve so its got to be some kind of temp sensor or maybe a diverter valve.
Old May 23, 2007 | 04:02 PM
  #39
Swansen's Avatar
the yellow plug is knock sensor plug
sandyota
Feb 4, 2021 11:16 AM
Eggslinger
Jun 8, 2019 03:32 PM
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
bryan34w
Jul 6, 2015 05:53 PM
