I am having a brake problem
Old Mar 26, 2009 | 07:41 AM
nv4runner's Avatar
Originally Posted by Flash319
Brake fluid is oil. I re-filled it with 80-90. seems good now....................
I also really hope you aren't serious about that. Brake fluid is sometimes a mineral oil, or silicon based, but for the most part it is glycol-ether based (DOT 3 & 4). What happens to brake fluid when it gets cold? Pretty much nothing. What happens to 80-90 when its cold? It gets thick. Oil may also react differently to the rubber brake lines and seals than actual brake fluid.
Why would the Mfg use brake fluid if oil would work just as well?
Old Mar 26, 2009 | 11:06 AM
Flash319's Avatar
80/90 works the best because it is so thick. You only have to push the pedal a little bit and the brakes lock right up. Its awsome.............
Old Mar 26, 2009 | 02:50 PM
sb5walker's Avatar
I know a guy who likes to harass rattlesnakes - pokes at them with a stick. I wonder what made me think of him. Hm. Well, anyway...
Just to make sure - you've verified the wheel bearing is fine?
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
skoti89
Sep 11, 2015 07:46 AM
Johntom240
7
Jul 13, 2015 12:18 AM
Jnkml
Jul 6, 2015 01:20 PM
