how would i add cruise control to my truck?
Old Apr 13, 2010 | 09:57 AM
516593812's Avatar
There has to be a way. I don't care if it doesn't look OEM/ Factory, as long as it works properly, I don't even care if it's not electronic (some kind of a dial setup?) it does have to be cheap!
any ideas?
thanks!
Old Apr 13, 2010 | 10:38 AM
xfactor203's Avatar
I imagine you could swap the cruise setup from a donor vehicle into your truck, though I would guess it would be a PITA (maybe I'm wrong). Re: a mechanical setup, I have seen homebuilt cable throttle controls using an old-style bike shifter mounted to the gearshift. I should point out that using something like this on public roads would be a bad idea, and might even have serious legal implications if it ever contributed to an accident.
Old Apr 13, 2010 | 11:29 AM
Tofer's Avatar
Sponsor
Goto home depot.
Buy a brick.
Bam instant cruse control
Old Apr 13, 2010 | 11:47 AM
peow130's Avatar
Originally Posted by Tofer
Goto home depot.
Buy a brick.
Step 1: Place brick on ground
Step 2: Slam head into brick
Step 3: ???
Step 4: Repeat
Old Apr 13, 2010 | 11:49 AM
yotaman85's Avatar
you would need to get the cruse control relays, throttle linkage, vacuum actuators, cables and the controls. yes it would be a PITA.
Old Apr 13, 2010 | 11:59 AM
516593812's Avatar
thanks for the imnput, i found exactly what i was looking for!
https://www.yotatech.com/forums/f129...4runner-75326/
Old Apr 13, 2010 | 12:03 PM
milehigheric's Avatar
Pretty simple actually if you are on the cluey side of life. There are hundreds of kits out there, some can look very OEM if installed correctly. It all depends on what you call cheap however. You are probably looking at around 350AUD +
Old Apr 13, 2010 | 05:44 PM
pruney81's Avatar
did you ever figure out how to get those brake pads installed?
Now, you're moving on to adding cruise control?
You move quickly my friend....
Old Apr 13, 2010 | 05:52 PM
yotaman85's Avatar
^^ha I've made a thread just have it answered in the first response..thats why I don't drink and tinker any more... sounded something like, "duuuudes, my door wont open!!! WTF!!?"
first reply, "did you try unlocking it.." (I didn't)
I dont think I responded and asked a mod to erase it... and yea, Im ASE certified!!! hahahaha I wonder why I was so stumped?:drin k:
in that particular order..
Old Apr 13, 2010 | 08:23 PM
Magnusian's Avatar
From: Downtown Heckronto, Ontario, Soviet Canuckistan
Cruise control, what's that? Is that related to this "power steering" stuff I keep hearing people talk about?
Old Apr 13, 2010 | 08:24 PM
yotaman85's Avatar
yea, its related to the air conditioning family.
Old Apr 13, 2010 | 08:31 PM
Magnusian's Avatar
What's air conditioning? I live in Canada, my air doesn't need soap, it needs heat!
Old Apr 13, 2010 | 10:03 PM
516593812's Avatar
i did figure out the brakes-much easier than i thought- i didn't even have to take the caliper off/ apart (the pins were a PITA to get out/ put back in)
Nathan_F
Aug 19, 2015 04:03 PM
punk1sk8er
7
Jun 24, 2015 01:33 PM
Briareus
10
Aug 24, 2002 05:33 PM
peterbilt
7
Jul 23, 2002 05:05 AM
