How many quarts do you use in 3.0's?
Old 03-08-2006, 10:35 AM
pruney81's Avatar
I just bought a 95 4runner with the 3.0 and the manual says it takes 4.5 or 4.8 qts. I can't tell which on it is. I had a 92 that used to take about 5.1 qts. I put in just under 5 how much do you guys use? I'm gonna drive it right now then check it again. I mean oil change with filter. thanks Paul
Old 03-08-2006, 10:39 AM
ChickenLover's Avatar
I always put in 5.
Old 03-08-2006, 10:48 AM
91_4x4runner's Avatar
Same, always 5.
Old 03-08-2006, 12:51 PM
pruney81's Avatar
Cool thanks I used one of those 5 quart jugs and spilled a little so I'm good I just didn't want to overfill it.
Old 03-08-2006, 01:10 PM
I imagine its better to overfill than to underfill. Use a funnel next time :-P
Old 03-08-2006, 01:46 PM
pruney81's Avatar
Yeah, I know I probably put in about 4.5 maybe a little more then started it and I heard a pretty loud ticking sound coming from my valves I think so I let it run for a few minutes then turned it off and put the rest in. There was only enough left to cover the bottom of the jug....Not even a half of quart, I just bought this truck and I've never heard the ticking before, could I have hurt the valves by starting it like a half quart low like that? I know I'm probably just being paranoid but it's funny it sounded alot queiter before.
Old 03-08-2006, 01:50 PM
pruney81's Avatar
P.S. It started idling a little lower than usual when I let it run for a couple minutes after the change. It was idling around 1000 rpm when I got it now it's about 800. It seems to have kind of a miss now.
Old 03-08-2006, 02:02 PM
sandcrawler's Avatar
another vote for 5.
idle at 800 (warm) is normal; idle at 1000 (warm) is not.
Old 03-08-2006, 02:05 PM
pruney81's Avatar
Yea but starting it a half a quart low right after an oil change won't hurt anything will it?
Old 03-08-2006, 02:17 PM
i would doubt it.
Old 03-08-2006, 02:24 PM
pruney81's Avatar
yeah I guess at 147,000 miles the valves could use an adjustment anyways
Old 03-08-2006, 02:29 PM
outrages112's Avatar
no you didn't hurt a thing. if you looked at the dipstick with 4 quarts it probably read full, once you start the truck let it run for a minute or so and recheck and it will be down about a quart. so just top it off. this is because the oil that drains out of the filter and the lines need to be pressurized to refill itself. and it is just as bad to overfill your truck, with too much oil it can be forced out the exhaust and ruin your cats.
Old 03-08-2006, 02:38 PM
JamesD's Avatar
I put 4.5 quarts. Five is overfilling it.
James
Old 03-08-2006, 05:13 PM
Originally Posted by JamesD
I put 4.5 quarts. Five is overfilling it. James
according to the FSM, the 3.0 takes 4.8 US qts with a filter change. so sure, 5.0 is "overfilling" it, but less so than 4.5 is "underfilling" it. but we're splitting hairs here -- seems to me that the spirit of the original post was just seeking reassurance that he hadn't screwed anything up while changing the oil.
Old 03-08-2006, 07:20 PM
Bobakazi's Avatar
You are fine. Personally, I use 4.7670345 quarts. Sorry for the razz. You are going to burn it off anyways. Oil does not require exact measurements, unlike rocket science. (disclaimer: I do not know anything about rocket science). Just get it close. If it was that big of a deal, there would not be a "Min" and "Max" on the dipstick.
Old 03-08-2006, 08:28 PM
LOCKnGO's Avatar
I put in seven,
but then use a Motorcraft FL1A filter and a relocation kit.
Old 03-08-2006, 08:49 PM
4x4Lamm's Avatar
I always put in 5+, maybe my dipstick is broken?
Lamm
Old 03-08-2006, 08:59 PM
photoleif's Avatar
i put in 4, check the dipstick and keep on pouring. it typically takes 5 when i'm done.
Old 03-08-2006, 10:23 PM
CoedNaked's Avatar
I put in 5.1 liters.
Old 03-09-2006, 02:37 AM
Banned for stupidity
V_Runner's Avatar
always 5
Quick Reply: How many quarts do you use in 3.0's?
