How heavy is a short bed?
Old Sep 17, 2008 | 05:25 PM
SwampThing's Avatar
How long will it actually last? Well acutally, it'll be replaced tomorrow (hopefully) with a nice piece of 1/2" thick steel.
How long would it have lasted if I kept it on there 24/7? Who knows. Can drop a couple more bucks for treated wood if you wanted to.
Old Sep 17, 2008 | 05:40 PM
abecedarian's Avatar
Originally Posted by SwampThing
Goood point. Where to find these shims...
4crawler sells shims
And I found out those shims are like $50... I think I'll just buy some shorter shackles. Think that'd accomplish the same thing, and would be easier and safer.
Lol, yeah I said it. Safer
Edit: Think I'm gonna make a new thread for the flatbed build. This is actually a great idea for someone who wants to build one for uber cheap...At lease it'll probably be a cheap idea to test right?
shorter shackles will reduce your lift and also rotate your pinion down towards the ground, possibly increasing the u-joint angle. so maybe read here (search the page for the word 'cardan'): http://www.4crawler.com/4x4/4R_suspension-III.shtml
Old Sep 17, 2008 | 05:52 PM
SwampThing's Avatar
Well I know about cv shafts. It's just that they want $250-300 to make mine into a cv, and I was like hell, I'll figure something out! lol...
Wow, only $7 for the 4crawler shims. That's badass. Just wondering if it'll work with trailgear's springs...
Old Sep 17, 2008 | 07:10 PM
Alex 400's Avatar
I would think they would seeing how the the springs have to fit to the stock mounting pads, so wouldn't that also mean that the shims would too?
Old Sep 17, 2008 | 07:16 PM
  #25
SwampThing's Avatar
Actually just measured... 2.25" wide perches and leafs, so they're a 1/4" wider than stock.
So I just realized I can't measure my driveline angles. Don't even have the transfer case or 3rd member in lol...
And also, as far as phasing goes, both joints are supposed to be lined like O==|=======O right and not ||==|======O right? If that makes sense...
Old Sep 17, 2008 | 07:37 PM
  #26
well, even though it's constant velocity, it's not a CV joint like the front is.
as for the shims, they mount on the pin between the spring and perch, so why wouldn't they work?
Old Sep 17, 2008 | 07:40 PM
  #27
yeah, the ends of the shaft should be mirror images of each other so:
]==[O|O]===========[
O==O]|[O===========O
(the verticle line | is the center carrier bearing on a 2 piece shaft)
additionally, the angles at each end of each shaft section should be as close to the same as possible
Old Sep 17, 2008 | 07:44 PM
  #28
SwampThing's Avatar
Eh, mine's a single piece with the slip shaft.
Well that's what I though. Mine's been clocked at 90º, but I've had no problems until I took off the bed and potentially changed the tcase and pinion angle to cause bad vibrations. Maybe it'll clear up if I clock it right... Dunno, guess it's something else to look into...
Old Sep 18, 2008 | 07:56 PM
  #29
SwampThing's Avatar
Wow, I dunno if it's the fact that I phased the dshaft correctly, or that I added about two coke bottles full of gear oil to the tcase, or what, but the noise/vibration is nearly gone. It's still there, and from the fact that I took off the bed no doubt, but I imagine once I get longer shackles or add some heavy plate for the flatbed or get some shims, it'll all go away. It's actually drivable now.
And I measured my angle and came up with FT-RT 47.13/16", and FB-RB 48.7/16". So that makes 1.3/8" difference, or 19.8º (right?). So is that within normal operating range for a single cardian driveshaft?
Old Apr 23, 2010 | 11:41 PM
  #30
harbor_bomber350's Avatar
well i skipped to the bottom because i didnt want to read it all but, alot of times its a ujoint that'll give vibs, even if it doesnt fell bad by doing a movement test doesnt mean its not, and if its not then you have spare trail parts for the glove box,
Old Apr 25, 2010 | 11:09 AM
  #31
Jay351's Avatar
holy bump! I thought Clint was back!
Old Apr 25, 2010 | 01:59 PM
  #32
Matt16's Avatar
The obvious solution to me would be to weight down the bed. Maybe a pole and some friends could help
similarity?
Old Apr 26, 2010 | 03:59 PM
  #33
Jay351's Avatar
Hahaha WIN!
88sasturbotoy
Jan 30, 2026 01:57 PM
rednecktoyotahunter
Nov 18, 2015 08:58 AM
94ofCanada
Aug 14, 2015 06:37 AM
agrout
Aug 13, 2015 06:12 PM
Nickdigg
Jul 7, 2015 06:04 AM
