How to fill transfer case?
Old Nov 24, 2020 | 05:35 AM
SideSwipe's Avatar
1986 4runner 22RE 4 speed auto
I know on the manual trans transfer case you have a basic fill and drain bolt. But on my auto trans transfer case i see the very obvious drain bolt but where do i fill it at?
Old Nov 24, 2020 | 07:55 AM
Jimkola's Avatar
YT Community Team
5 Year Member
I think this is it. circled in red. the Toyota part numbers listed are the same fill plug numbers on the mtm transfer. Judging by the picture it should be in approximately the same location as the mtm.
Old Nov 24, 2020 | 08:07 AM
SideSwipe's Avatar
Ok so the pan in your picture is the pan for the transfer case? cause i now see the fill and drain bolt on the back of the transfer case so what is the bolt on the little pan for?
Old Nov 24, 2020 | 08:09 AM
SideSwipe's Avatar
drain and fill plugs on back
oil pan behind trans oil pan with drain bolt?
pics of what im talking about
Old Nov 24, 2020 | 09:24 AM
Jimkola's Avatar
YT Community Team
5 Year Member
Looking at the FSM, the fill and drain plugs at the back of the transfer case are isolated from the rest of the unit, I think just for the chain. The FSM shows servicing the ATM by draining both pans, the one for the trans and the other for the transfer, then filling via the dipstick tube with Dextron II. 4.8 qts for the transmission/transfer case. I don’t see how much Dextron II for the rear chain case, it says just to fill until fluid comes out the fill hole.
Old Nov 24, 2020 | 02:01 PM
SideSwipe's Avatar
Jim you are the man thank you
Chumlee780
Nov 13, 2015 03:18 PM
KBar
Jun 30, 2013 07:18 PM
coronadrinker85
Feb 21, 2011 08:09 PM
deSCHUTTER
Feb 4, 2007 12:56 PM
autodriver
Oct 30, 2004 11:46 AM
