How does my 22RE exhaust sound?
Old Mar 6, 2019 | 09:12 PM
toyotadood69's Avatar
I bought this 1991 Xtra cab pickup with 266,000 miles on it. No cat, flowmaster 40 muffler, stock manifold. Apparently the head had been worked on but not the block. However, the block and the transmission are painted blue which makes me believe that possibly the motor was pulled and worked on by a previous owner. She burns oil on steep compression braking, and has some really loud lifter ticks, but still goes strong! To me, its one of the deepest sounding 22RE's I have heard, and the idle seems slightly different. Does anyone think that maybe there could be a cam or maybe even a slight bore on the block judging from the sound? Or am I just hearing things and getting carried away. Should I be worried about all the valve noise?
Exhaust:
Valve Clatter:
Old Mar 7, 2019 | 03:51 AM
87-4runner's Avatar
For peace of mind I'd go thru the valves and make sure they're in spec...
Old Mar 7, 2019 | 03:53 AM
87-4runner's Avatar
sounds good... sounds normal... idle is a bit fast for my liking...
Old Mar 7, 2019 | 04:24 AM
Melrose 4r's Avatar
5 Year Member
Flowmaster 40 sounds nice on these. To my ears, the cam sounds stock. Next time you have the valve cover off, get a dial indicator and measure the travel of the valve as you rotate the engine to determine valve lift. Compare to stock specs.
Old Mar 15, 2019 | 07:08 AM
ev13wt's Avatar
5 Year Member
Sounds like an exhaust note only.
Old Oct 6, 2019 | 08:14 AM
YotaWolf91's Avatar
Exhaust:
https://www.youtube.com/watch?v=PMfpr92dFWI
Valve Clatter:
https://www.youtube.com/watch?v=7qvhQEdyKE4
What tailpipe size are you running man it sounds nice
Old Oct 6, 2019 | 11:54 PM
ev13wt's Avatar
5 Year Member
Sounds like mine.
But I am tired of the noise. Putting a quiet on on right now.
You have such a nice bumper, consider removing that licence plate and placing it neatly?
mattyboi
Aug 18, 2017 08:01 AM
bryy
Dec 22, 2013 12:30 PM
toyota4x4907
Dec 21, 2012 06:02 PM
wilshire
May 9, 2009 02:30 PM
ByThaBay
Aug 13, 2003 03:19 PM
