How to deal with a rounded tranny fill bolt...
Old Feb 11, 2010 | 06:03 PM
Toyomo's Avatar
SHould've expected it. I was about to change the oil for the tranny today, but I can't undo the fill bolt at all. I PB blasted the hell out of it, used a hammer to tap it slightly and it ain't budging at all.
Anyone have any suggestions/ideas for this? Luckily I didn't undo the drain plug first, but do they sell replacement fill/drain plugs at the auto parts stores or is it a dealer only item?
Old Feb 11, 2010 | 06:07 PM
mightymouse's Avatar
junkyard! Probably get it for free if you throw it in your pocket. Not saying i condone that kind of behavior but to each his own. plus while your there you can find other crap you need. If you like me a trip to the local yard has yielded many good finds even when i'm not looking for anything. Otherwise yeah probably the dealer.
jason191918's Avatar
#1 Try a pipe wrench.
#2 Weld a nut to it.
#1 failed for my rear diff, but #2 worked like a charm. From the heat of the weld, it was finger tight afterward.
I bought mine at a local parts store.
Old Feb 11, 2010 | 06:15 PM
1989toy4wd's Avatar
vice grips + Hammer???
If its already rounded off then you dont really have to worry about making it worse!
Old Feb 11, 2010 | 06:17 PM
67ghiaTIV's Avatar
I have had succuess using a punch or chisel on the edge and tapping it with a hammer if you are having trouble looseing it.
Jamie
Old Feb 11, 2010 | 06:23 PM
874runnersr5's Avatar
Extractor sockets?
Old Feb 11, 2010 | 06:31 PM
89silverpu's Avatar
You can always take the shifter out and fill it through the shifter hole as well with a funnel. That's what I did when I found out my fill plug was stripped.
Old Feb 11, 2010 | 06:36 PM
Toyomo's Avatar
Oh. I just might end up doing that. I gave up for the night, has anyone had any success with the extractor bolts? I can pick up a set at sears for 20 bucks.
allnmstkn313's Avatar
Heat+Vicegrips.
Failing that weld on a nut and be done with it.
Old Feb 11, 2010 | 06:38 PM
a nut is a couple of bucks and a 6 pack is cheap. have a buddy weld a nut on
Old Feb 11, 2010 | 06:44 PM
camo31_10.50's Avatar
i always grab atleast a couple drain plugs if there is nobody lookin lol
and the thought (i'm NOT going to do this...it's just a straight up bad idea..LOL) has crossed my mind before on going into the yard after dark and getting a grille for my '86 that they want $75 for!!!!...like i said though..i don't steal...lol and i have asked the owner of the yard before if he minds me grabbin bolts and such and he don't care, but his employees flip over it lol
Old Feb 11, 2010 | 06:52 PM
Slowrunnin's Avatar
I just changed my tranny and transfer case fluid a couple weeks ago. I used a Impact gun to remove the fill and drain plugs. Just make sure you hold the gun on there firmly.
Old Feb 11, 2010 | 07:01 PM
He already rounded it off.
Old Feb 11, 2010 | 07:30 PM
yep.. its what i use at the shop.
Old Feb 11, 2010 | 08:46 PM
dropzone's Avatar
Fossilized
that is why the allen head insert fill/drain plugs are the choice for replacement...
Old Feb 11, 2010 | 09:00 PM
The aftermarket hex head one's are about 3 times as thick as the stockers, making them a lil bit harder to strip.
Old Feb 11, 2010 | 09:18 PM
tc's Avatar
tc
Anti-seize and aluminum washer when you put it back in.
Steel bolt in aluminum casting = no bueno
Old Feb 11, 2010 | 10:16 PM
mick cassidy's Avatar
been there done that first off get a PROPER SOCKET i think its a 22 mm DONT FORK around with trying to find a standard thats close thats why this happened !!!
hammer and chisel it out tapping it out one tap at a time its soft alum now get a replacement from the boneyard or da dealer and lesson learned metric on metric
Old Feb 11, 2010 | 10:44 PM
nj110167's Avatar
Vise Grips and a hammer
Old Feb 12, 2010 | 05:14 AM
RustBucket's Avatar
24mm
Apply heat with a torch for a few seconds and tap the bolt head tangent to the center with a chisel and hammer.
