how can i tell what gears i have in rears?
Old Oct 17, 2007 | 01:51 PM
tedfrk's Avatar
i have an 87 4runner with a 5 spd 22re motor,how can i tell what gears i have ?it is stock.
Old Oct 17, 2007 | 02:26 PM
InternetRoadkill's Avatar
The pinion will have a color code painted on the stub. The manufacturer's plate on the center of the firewall will also tell you.
Old Oct 17, 2007 | 02:36 PM
Jay351's Avatar
Lift up one of your rear tires, make a mark with tape or chaulk on the tire and a refrense mark on your fender.
Then mark the driveshaft.
Spin the tire 20 times, take the number of rotations the driveshaft turns and divide it by 10. And thats your gear ratio.
For example:
Spin tire 20 times, driveshaft spins 45.6 times 45.6 divided by 10 = 4.56 gears.
Also, your door sticker should tell you what gears are in the truck, but they can be wrong.
Old Oct 17, 2007 | 02:38 PM
jason191918's Avatar
this might clear things up
http://www.brian894x4.com/Gearratiosanddiffs.html
Old Oct 17, 2007 | 02:40 PM
UKMyers's Avatar
Or you could do it the easy way
http://www.toysport.com/Technical%20...ifications.htm
Old Oct 17, 2007 | 04:17 PM
Djlarroc's Avatar
Thanks for the links! My suspiscions have been confirmed. I have 4.10s.
Old Oct 17, 2007 | 07:56 PM
Gatekeeperman's Avatar
Wow nice info... I always thought my gears in my 89 felt lower. but I had no idea they where 4.56's
Thanks!
XtraCab
Apr 12, 2020 05:25 AM
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
mengquis
Jul 13, 2015 10:39 AM
Jnkml
Jul 6, 2015 01:20 PM
