How to: Add a headlight buzzer alarm (w/ pics)
Old Nov 11, 2013 | 10:38 PM
RAD4Runner's Avatar
Originally Posted by Grego92
Yes, please take the advice from Ray about where to wire into for this mod. I DO NOT RECOMMEND FOLLOWING MY PICTURES or method of tapping into the ignition area. Although it works, it gave me problems when I installed H4 headlights and a wiring harness. For some reason tapping into the ignition area triggered both the high beams and low beams to come on at the same time. As soon as I disconnected the wiring my H4's worked fine. I still need to rewire using the more appropriate (downstream) place that Ray used.
Thanks, Grego.
BTW guys, IF you have a first-gen here's another option: The green wire (the segment in yellow heat-shrink) in pic below is another good place to tap positive +12V from that is on only when tail lights are on.
Please note that picture shows it cut in order to do my deck lamp mod (also on my build thread).
Jcrawl94
10
Oct 24, 2015 04:34 PM
Sep 4, 2015 09:27 AM
mldave
Aug 10, 2015 09:23 AM
defrag4
Jul 31, 2015 10:50 AM
Esibnitsud
Jul 30, 2015 08:19 PM
