Hot ignition?
Old Dec 1, 2009 | 03:50 AM
Greybeard LTD's Avatar
Hot ignition?
I "fried" a set of plugs on a 65 miles per hour plus (time constraints) run across the U.S. with a 3VZE powered, 6000+ pound 21 foot, Motorhome. I replaced the Champions (installed by former owner) with a set of colder NGKs, but I would still like to improve the ignition system. Cap, rotor, and wires are new. Any suggestions here for an aftermarket system? Oh yeah, I'm open to any simple bolt-on power or mileage improvements too.
Old Dec 2, 2009 | 06:58 PM
abecedarian's Avatar
What do you mean by "fried"? Burned the electrodes I'm assuming, by your choice of a colder plug.
To me, it sounds like you're either leaning out at higher rpms, something you won't fix by upgrading the ignition system, or have too much ignition advance.
Old Dec 2, 2009 | 08:02 PM
By "fried" I mean it ran very bad, very hard to start when I got home. I knew I ran it hard, lots of long third gear pulls, so I pulled the Champion spark plugs, installed NGKs, and it starts fine now. I don't think the ignition caused any plug problems, I just want a better spark. I also think I may have got a tank of bad fuel during my cross country trip, through part of WV it ran especially bad.
Old Dec 2, 2009 | 08:12 PM
myyota's Avatar
The stock ignition that toyota used is actually quite good, provided that you keep up the required service when needed. Make sure the timming is properly set and the valves are adjusted properly, cap, rotor and plugs are replaced when needed and you shouldn`t have any problems. Also using good quality gas helps alot.
Old Dec 2, 2009 | 09:52 PM
Have some pictures of the Champion plugs you pulled out?
That would go a long way in helping to figure out things.
Old Dec 3, 2009 | 03:38 AM
I tossed the plugs, but they were gray, not the usual light brown. They didn't look very bad, the diagnosis was more by the "seat of the pants". My next step is a good fuel injection cleaner in the tank and cleaning the throttle body. If that doesn't help it's off to the local repair shop. It's getting cold in PA and my shop door is only 8' tall. The RV is 9 1/2' high, and I don't relish seting the valve clearance in the cold.
Gutted91
Jan 3, 2020 09:48 AM
tazman1972
11
Sep 28, 2015 10:32 PM
87runner_
Sep 19, 2015 03:28 AM
JHalcyonM
Sep 14, 2015 01:10 AM
anndel
Sep 10, 2015 08:50 AM
