Home Grown Air box/Snorkel
Old Mar 28, 2010 | 04:49 PM
MuddinRI's Avatar
Ok so I've had this idea for a bit about a snorkel setup. So when i rebuilt my motor i switched the battery to start. started the air box this week. I ran into a few problems while trying to figure how to run the hose. SO....... I did my own thing lol never seen anyone do this probably cause it's retard... still finishing it up in my spare time.
I'll get more pictures of it hooked up this week. I ran it down and then up into the fender well. Anyone know where to get just the top of a snorkel?
Thanks
Old Mar 28, 2010 | 05:19 PM
BigBluePile's Avatar
Look HERE:
https://www.yotatech.com/forums/f88/...norkel-194369/
its in there somewhere...
Old Mar 28, 2010 | 05:41 PM
MuddinRI's Avatar
ya i looked at that thread before i started mine.. not sure if i want t o go out of the fender or out of the cowl like he did.... suggestions are more then welcome....
Old Mar 28, 2010 | 06:03 PM
MuddinRI's Avatar
Come on ppl post your opinions.... I'm curious to know what the pros say... I'm just starting to modify my truck and would appreciate all the suggestions i can get. Next on my list is a lift, i'm going with 2" ball joint spacers and new shackles possibly springs too.
Old Mar 28, 2010 | 06:16 PM
ah, you do know that you pretty much HAVE to go out the FENDER to get to the COWL right? are you SURE you looked thru that thread?
Old Mar 28, 2010 | 06:24 PM
MuddinRI's Avatar
ya i saw how he went but i have factory bumper and there is a bracket right where the intake hose would go. so i went down and then up for that reason and the fact it will be alot harder for water to get in there.
Old Mar 28, 2010 | 06:32 PM
huh?
Old Mar 28, 2010 | 06:34 PM
weaselman's Avatar
it looks HUGE?
MuddinRI's Avatar
i could not got through the inner fender because i had a bracket holding my bumper and or the fender. so i went down as you can see in my pics.
I do like that box you made, very nice! How's the filter mount in there?
Old Mar 28, 2010 | 06:36 PM
vital22re's Avatar
totally a bro
so... what you're saying is... you gonna fill the wheel well up with the piping and go out from under the truck and then up the fender to mount your snorkel?
Old Mar 28, 2010 | 06:37 PM
MuddinRI's Avatar
it's really not that big. it just fits a cone filter. it gets a bit wider under the mafs to ad support yo it. the dimensions are 7" wide 9" long and 8" high.
Old Mar 28, 2010 | 06:39 PM
MuddinRI's Avatar
it 90's right under the plastic fender cover. it doesn't seem to be in the way of anything i'll post more pics soon
Old Mar 28, 2010 | 07:12 PM
Ah. Looks good so far!
Old Mar 29, 2010 | 04:43 PM
MuddinRI's Avatar
Ok i got some better pics of what i'm trying to set up. I have yet to cut any exterior holes....
Here's the box, i put some bike tube to make a gasket on the cover.
Everything dry fit
I got an idea of how i'm going to come out of the fender, a buddy of mine gave me a piece off his intake from a chevy v6 (i'll get a pick of it later) thinking of this piece with a 90 facing the windshield so it doesn't suck water..
Old Mar 29, 2010 | 05:00 PM
Looks good man!
Old Mar 29, 2010 | 05:59 PM
Rooke1991's Avatar
whats an airbox do? im a complete noob.
Old Mar 29, 2010 | 06:03 PM
kiyobrown's Avatar
Logan has an airbox that leads to a snorkel (read his thread). I have a batt intake swap, no snorkel. So our filters sit at the same place, but he gets clean ambient air, and I get ambient/engine heated air. We are doing an experiment to see the diff. On the freeway, he gets whatever the outside temp is, I am about 5 degrees higher. No biggie. Now on the trail, Logan was pulling 72 degree air, mine registered at 112 degrees at the filter. Airbox will block heat from the engine from going through the intake. Cooler denser air makes the engine happy.
Old Mar 29, 2010 | 06:05 PM
MuddinRI's Avatar
It's just a mod to put a snorkel on.. I don't think the stock box would work so i built this.
Old Mar 29, 2010 | 06:08 PM
MuddinRI's Avatar
yes it does!! i had just the cone on for a bit notice it made lots of noise and little power gain if any, figured it was just sucking warm air. Plus with it being behind the light it doesn't get a good flow. I'll finish what i'm doing and see if it helps. if i don't like it i'll re think it i guess
