Hillbilly cruise control/hand throttle?
Old 02-12-2007, 08:57 AM
curtiswyant's Avatar
Hi, I'm wondering if anyone has setup a simple control cable to act as a "manual" cruise control on their truck? I've seen a couple hot rods with a push-button control cable attached to either the carb or gas pedal...push the button and pull to adjust, push to button to release. I can't imagine it would be too safe but...who knows. The aftermarket kits seem like a hassle...
Old 02-12-2007, 09:45 AM
Robrt32's Avatar
Yea , I know what your talking about but IMO i don't think it wouls be a great idea on a Auto.......to each his own but be carefull
Old 02-12-2007, 09:50 AM
mt_goat's Avatar
Search around, some manual tranny guys use a hand throttle for rock crawling.
Old 02-12-2007, 09:51 AM
It's a manual transmission. Maybe I could make a kill switch for extra safety
Old 02-12-2007, 09:59 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Funny...just yesterday I was wishing I had a cruise control on my '86...M/T. I figured I'd have to have a different ECM for that.
Old 02-12-2007, 10:02 AM
mt_goat's Avatar
Actually the CC has it's own computer:
http://personal.utulsa.edu/~nathan-b...10cruiseco.pdf
Old 02-12-2007, 10:15 AM
thook's Avatar
Any info on setting CC up on a stock 1st gen (22re)? If the price is right, I would like to do this at some point.
Old 02-12-2007, 10:37 AM
4Crawler's Avatar
Hand throttle:
- http://www.4crawler.com/4x4/CheapTri...leInstallation
Doesn't work that well for a CC, though, unless you are on dead flat roads.
An aftermarket cruise control is probably the easiest to install, I used an Audiovox unit in my daily driver:
- http://www.4crawler.com/Diesel/Cheap...eControl.shtml
Old 02-12-2007, 10:45 AM
Yota Tony's Avatar
Use a bike brake lever tied into your throttle cable.
That's what I've done before and never had any issues.
I've used brake cable for a bike and it's just spliced together so it shouldn't cause any problems.
Old 02-12-2007, 10:52 AM
thook's Avatar
Thanks a bunch you all! Dead, flat roads are all I'd be using it for, anyway. I have 26mi of highway to get from home to work/town and CC would be just a luxury.
Bike brake lever? The cable I understand, but the lever? I guess I'll have to do some reading. I just don't understand how that works at the moment. This is all news to me! LOL!
Old 02-12-2007, 11:22 AM
Does the bike lever stay locked in position? It doesn't seem like it would be easy to release quickly, and I want something that I don't have to hold in position.
Old 02-12-2007, 12:20 PM
thook's Avatar
That's what I was pondering. I don't believe it will...effectively. I think it's just for having a "hand throttle" saving your feet for propping up through the window or something...dash, significant other...I dunno. Anthony?
Old 02-12-2007, 12:31 PM
Here's basically what I'm thinking of using...
http://cgi.ebay.com/ebaymotors/ws/eB...0097143&rd=1,1
Old 02-12-2007, 02:14 PM
CyMoN's Avatar
I have a steering column with the cruise control and all the other parts as well for 75$ and the TB from the truck 100$ plus shipping for everything and it yours.
it is off a 87 sr5 4runner
Old 02-12-2007, 03:40 PM
Yota Tony's Avatar
The lever I've got is made by Tektro (the other one is on my BMX). It is spring loaded however it's got an adjuster screw so I can set it to keep the truck at a certain rpm or not.
If you want a Cruise control, your best bet is an aftermarket unit.
Old 02-12-2007, 03:46 PM
Bill's Avatar
I used an old thumb shifter for a bike front derailleur, they type that index the whole way rather than "1, 2, 3". And a length of bike shifter cable and housing. It worked really well actually.
The only thing I noticed is that after a while it started to make my throttle stick a little bit. So I even with the "low friction" cable housing, I still had to put a bit of oil on the cable now and then.
Old 02-12-2007, 04:30 PM
thook's Avatar
Very nice Curtis. That's a good price, too.
Thanks anyway, Cymon. I don't have that kind of cash right now. BTW, is that for the 3.0 or 22re?
Break lever, thumb shifter!?....wanna hear my idea?...the defunct lever for my heater...lol! Hey, I dunno...fun ideas. I might go for something like that ebay item . I even have a spot just for it on my dash!.....(scratching my beard while pondering the possibilities...)
Old 02-12-2007, 04:36 PM
CyMoN's Avatar
its for a 22re
Old 02-12-2007, 04:39 PM
Bill's Avatar
That'd be pretty cool. although, I hope you live in a warm climate...I use my heater.
You might run into an issue running a cable into the dash though. I used a thumb shifter on the shifter because it was easy to route the cable, and keep it neatly tucked away.
Old 02-12-2007, 06:10 PM
jmcbmx's Avatar
you dont want to use a brake lever off of a bike, you want to use a shifter lever so that it clicks into different positions.
Quick Reply: Hillbilly cruise control/hand throttle?
