High pitched noise coming from rear of truck when moving
Old Aug 14, 2008 | 12:46 PM
esoterik's Avatar
Ok guys I seriously need help with my truck. Lately I have been hearing a high pitched noise from the rear of my truck when moving at speeds above 35+ mph. Its a very distinctive noise and I seriously feel like a dog because it drives me nuts.
Does anyone have any clue on what it could be? A search turned up a not so clear answer.
Thanks in advance
Old Aug 14, 2008 | 12:53 PM
4Crawler's Avatar
Might check the u-joint and pinion flange on the rear driveshaft.
Old Aug 14, 2008 | 01:30 PM
abecedarian's Avatar
does it make the noise all the time, or when only accelerating or only when decelerating?
by high pitched, do you mean like a sqealing, creaking or whining?
if it's a squealing, it may be something in the brake system, but usually that's a disc brake type noise.
if it's creaking, like door hinges sound sometimes, the u-joints may be dry and needing greased or replaced.
if it's a whining, or maybe even a high pitched howl, the pinion bearings may be loose or you may need to drain and refil the differential.
Old Aug 14, 2008 | 01:41 PM
esoterik's Avatar
Thanks for the response guys.
The noise is on acceleration and deceleration, and goes away when I finally reach a stop.
The squealing is very high pitched. The diff fluid was changed like 1k miles ago although it was filled with a mix of 1qt 80w and 1 qt75w-90 gear oil (don't ask long story)
I'll replace the diff fluid again today with the correct blend of full 75w-90 and replace the ATF again.
Old Aug 14, 2008 | 02:11 PM
definitely check your u-joints. if the bearings in the joints are dry, metal on metal, they can squeal quite loud and high-pitched.
voiddweller
19
May 2, 2016 09:10 PM
cchinny
Jun 25, 2015 08:11 PM
dirtrider0129
10
Jun 24, 2015 12:24 PM
Mr.Black
Jun 21, 2015 10:17 AM
