High oil pressure gauge readings
Old Aug 17, 2009 | 06:39 AM
Squiddy's Avatar
Put in new engine (3.0, discussion elsewhere). 1500 miles later, engine running great. Issue now is following. My aftermarket oil pressure gauge is pegged at 100 all the time. Wires/leads/grounds seem fine. Sending unit is in the most forward hole in the block (https://www.yotatech.com/forums/f116...ensors-153167/). In past pressures were OK, tho perhaps a bit high -- was suggested this was because the sender was right near the oil pump. So may be able to fix by moving to "next hole back," but would appreciate thoughts.
Old Aug 27, 2009 | 05:05 AM
Squiddy's Avatar
Bump
Old Aug 27, 2009 | 05:18 AM
vital22re's Avatar
totally a bro
try another gauge to test. or maybe theres a blockage? maybe teh pressure relief valve in the op is stuck ? does it read high when you turn the key but before you start? does it drop after the truck sits for a while?
Old Aug 27, 2009 | 06:12 AM
TNRabbit's Avatar
That's very impressive, considering the threeveezy has the lowest average oil pressure I've ever observed on an engine....
Old Aug 27, 2009 | 03:36 PM
Squiddy's Avatar
Oy, I am a dope...I forgot to look at whether this came on just with key in "on" position, or with ignition turned. It spikes to 100 with the former. So it must be [purely] an electrical issue. I would think a short to ground before the sensor would make reading "0," but... Maybe the prob is they over teflon'd it when new engine put in, and not a proper ground into the block. Obviously need to pull, as well as getting the multimeter out.
Old Aug 27, 2009 | 04:03 PM
abecedarian's Avatar
Putting a mechanical gauge in just to verify things is highly recommended.
Such high oil pressure will cause bearings to spin and cut off their own oil supply leading to galling and seized bearings as well as damage to the crankshaft, connecting rods and <insert lubricated component here>.
Old Aug 28, 2009 | 11:47 AM
Squiddy's Avatar
Note my previous posting...it's electrical
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Yota.Jay
Jul 23, 2015 08:08 PM
skoti89
Jul 8, 2015 12:05 AM
HRDC0R19
Jul 5, 2015 06:43 PM
