High beams suddenly stopped working
Old May 19, 2014 | 04:10 PM
bowtierebel's Avatar
Sorry, I had just read through the thread when I posted that question. Up above Terrys87 has posted a pic of the plug with the yellow wires that I'm talking about. On mine the yellow wires plug into the other plug end, but the wires on the other side of the plug are a different color. Scroll up and you can see the pic with the plug with the yellow wires that I'm talking about.
Old May 19, 2014 | 05:45 PM
RAD4Runner's Avatar
My headlights started doing the same as you guy's did... I pulled and cleaned the contacts, but no joy...
A problem well-stated is a problem halfway to being solved.
People above have various symptoms. Why don't you describe exactly what's going on with yours? What do you do and what should be happening but not happening?
Originally Posted by bowtierebel
Sorry, I had just read through the thread when I posted that question...
I see. That white connector has nothing to do with the lights. That's for the wipers.
Go schematic for you truck? If not, see schematic I posted ^^^
Old May 20, 2014 | 02:22 AM
Well, that's the thing... I don't think I'm having any problems. Everything seems to work. I did notice that the wires went to the wipers. I still have the delay, washer, ect. I was just wondering if anyone knew what the were for since the other wiper/headlight switch assy. didn't have those wires and I also noticed that the other '86 assy. that I put in had one less wire/pin inside the plug assy. where the one steering harness plugs into the 2 black plugs going under the dash. I just didn't want to find out later that something didn't work right or not at all after it was all back together. I didn't try to start the truck though, come to think of it. I just turned the switch to "RUN"position to check the other things.
Old May 20, 2014 | 08:20 AM
RAD4Runner's Avatar
My headlights started doing the same as you guy's did. I pulled and cleaned the contacts, but no joy...
You had a problem...
...I checked operation of everything with out starting the truck and everything seemed to work.
You do not have a problem...
I'm concerned that I may find that something doesn't work after I get it all back together...
If it ain't broke, don't fix it
Well, that's the thing... I don't think I'm having any problems. Everything seems to work...
No you do not have a problem.
What is it really?
Scotttekoch
23
Nov 1, 2021 12:41 PM
gog1968
Jun 22, 2015 05:55 AM
tpg013
Jun 27, 2002 02:16 PM
LSUMatt1514
Jun 26, 2002 05:03 AM
