The Herculining entire 4runner interior project thread..
Old Feb 22, 2009 | 02:12 PM
chrisbnaz's Avatar
Originally Posted by AndyL
Just kinda curious - how are you planning to deal with the cable for the gas tank pop; and those wiring looms? Just going to line over them or?
I was actually thinking about lining over the gas door cable..All my speaker/amp wires I re-routed through the door sill or whatever you want to call it...The big factory wire looms I need to find a solution for as they're too big to fit where I routed the speaker/amp wire through.
Just finished the first coat on the backseat portion.
Old Feb 22, 2009 | 02:27 PM
scuba's Avatar
Wow Chris, Lookin fantastic !! Happy Belated btw !! Cant wait to see it done
Old Feb 22, 2009 | 02:28 PM
chrisbnaz's Avatar
Quick edit about the gas door cable..Solution...Take it out! I pulled the cable out, cut off the release mechanism that its attached to, put the release back on and shut it..Toyota was smart, you can use the key to open it if the cable breaks..So now I just use the key instead of pulling the knob in the cab..No big deal.
Old Feb 22, 2009 | 03:20 PM
cormel's Avatar
Nice job, hope it works out good for you and does not peel.
Old Feb 22, 2009 | 06:01 PM
  #25
AndyL's Avatar
I was actually thinking more about snagging a tercel gas filler pop (mounts under the seat) for mine - reroute the cable under the seats - out of sight... The looms have me baffled too - I'm thinking about using some of the corugated plastic wire guard to encase them before rolling, then they're at least slightly protected, and can be extracted if needed.
Looking forward to your impressions after finishing... I've got my carpet all pulled, most of the deadner pulled up - and half prepped; and the road noise is starting to bug me already...
Old Feb 22, 2009 | 06:23 PM
  #26
phildelfino's Avatar
I wished I had a key for the gas door.
Looks like you're doing a good job.
Old Feb 22, 2009 | 06:57 PM
  #27
Junkers88's Avatar
Isn't it the ignition key? If not then I'm hosed because all I got were two ignition keys with the 4runner.
Old Feb 22, 2009 | 07:11 PM
  #28
littlecommando's Avatar
yea, it is the ignition key
thats the only way that i can get mine open, cause mines missing a spring
Old Feb 23, 2009 | 01:40 PM
  #29
Junkers88's Avatar
Chrisbnaz,
Hey are you planning on putting carpet or something back in the runner when you're done? I want to do this to mine as well but am a little concerned about road noise. I'm considering using some of that 1 inch thick rubber trailer matting in the cargo area to cut back on noise and such.
Old Feb 23, 2009 | 02:41 PM
  #30
chrisbnaz's Avatar
As of right now, I have no plans to put any sort of carpet back in it. It is an option at a later time if I'm not happy with just the herculiner.
I've made a lot of progress, just working on misc. odds and ends now and slowly starting to put the interior back together. I'll have pictures up hopefully tonight if I have time.
Old Feb 23, 2009 | 06:01 PM
  #31
riceburner's Avatar
Looks nice. Is it thin enough that you will you be able to remove the fuel pump access cover if the pump dies? The access cover is an awesome little feature.
Old Feb 23, 2009 | 06:53 PM
  #32
rock slayer's Avatar
hey i was thinkin of doin this to mine but i hate dealing with the tar gunk thats under there on my '90 is there an easy way to deal with that cause if not i think i will leave the carpet
Old Feb 23, 2009 | 08:16 PM
  #33
chrisbnaz's Avatar
Alright..Tonights quick update..Put another 12 hours in today on this damn thing..Turning out to be a very time consuming project but I like the way it's coming along and it'll be worth it in the end..The following pictures are where I'm currently at, next weekend I will pull everything back out and do another coat. I needed to throw the interior back in so I can go to work in the morning! lol.
I didn't take as many pictures today, I was just trying to get as much done as I could and took a picture here and there when I got a chance.
I'm now off to take a shower with acetone.
Old Feb 23, 2009 | 10:44 PM
  #34
IngSoc's Avatar
Looks pimp. Yup on my list of crap to do but boy is my cab DIRTY. Im sure every one here knows that thoe. The way I se it is that as of right now I got more time then money, so might as well do it my self.
Jun 1, 2021 01:51 PM
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
shar
Jul 9, 2015 12:38 PM
karbin
Jul 5, 2015 11:37 PM
