help-stripped exhaust manifold bolt
Old Apr 16, 2006 | 03:42 PM
AH64ID's Avatar
I had to helicoil my head for one of the air-injection bolts when I was installing my header. It gauled and had to be over drilled...it never had a problem after that. I will probally use never-seize when I put the header on this rig.
Old Apr 17, 2006 | 04:41 AM
PirateFins's Avatar
Originally Posted by prerunxj93
thanks for the info just had this happen to me. 60mm was way to long though r u sure that was the correct lenth?
60mm stud, not a bolt. Mine was on the top part with the air injection and worked perfect. But that was only because the first few threads were trashed. If the whole thing is trashed, than a Helicoil is your best bet like said many times.
Blamalam
Mar 12, 2022 07:34 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
accuracy
Aug 6, 2015 12:32 PM
87blyota
Jul 10, 2015 04:31 AM
