HELP pls, can't find tie rod to heim adapter for my pickup
Old Apr 29, 2017 | 04:23 PM
IdoHilux's Avatar
Hii Everyone, i'm looking for tie rod adapter stud to heim,
and i can't find any adapter in my size
the Bottom thread: 9/16
and the Top Thread: 5/8
the only result is 5/8 to 7/16 and it's not fitted in my stock setup
thanks !
i need adapter like this one :
http://www.speedwaymotors.com/Adjust...Heim,3333.html\\
Attached Thumbnails HELP pls, can't find tie rod to heim adapter for my pickup-20170429_214034.jpg
Old Apr 29, 2017 | 04:26 PM
IdoHilux's Avatar
i can't edit and add pic.
Old Apr 30, 2017 | 05:54 AM
wyoming9's Avatar
Red face
If you have exhausted all sources !!!! the best you can do is find a local machine shop that does small custom jobs .
Take all your parts explain what you want done ask for a price if it is acceptable give them the deposit they want pick them up when done .
Since these are Custom might be good to have extras
If not figure out another way to do what your trying to do.
Old Apr 30, 2017 | 08:22 AM
dropzone's Avatar
Fossilized
why not ream it out to the proper size and skip the adapter? Looking at the angle of your CV's it doesn't look like you are running long travel or anything special that would require the use of Heim joins
good info on why to use TRE http://www.fourwheeler.com/how-to/13...-tie-rod-ends/
why are you using heims and not TRE's?
have you tried:
http://www.ruffstuffspecialties.com/catalog/
https://www.ballisticfabrication.com/
http://www.barnes4wd.com
Old May 2, 2017 | 11:09 AM
IdoHilux's Avatar
have you tried:
Hii sir,
i can't find the item i need at all of the sites thats you just added
this is the reason
Attached Thumbnails HELP pls, can't find tie rod to heim adapter for my pickup-20170501_165037.jpg   HELP pls, can't find tie rod to heim adapter for my pickup-20170501_164813.jpg
Old May 2, 2017 | 11:32 AM
dropzone's Avatar
Fossilized
Dude Who put your front end together?
I think someone mounted the steering arms on the bottom, they are supposed to be on top. i could be totally wrong but your front end doesn't look right to me. did you crank your torsion bars or something?
ignore the red circle, borrowed pic from 4crawler off road
you may try contacting http://blazeland.us/
nate might have a suggestion for a source of TRE or heims for you
again I could be totally off on your IFS, but even with a steep angle it doesn't look right to me
Old May 2, 2017 | 11:48 AM
IdoHilux's Avatar
whats wrong here?
i think my torision bar is fine,why?
Old Jun 15, 2017 | 11:58 AM
BlazeN8's Avatar
IdoHilux,
Total Chaos has a tapered insert that allows you to use a straight bolt. It reduces the ball stud shaft to a 1/2" straight bolt. To counteract the reduction diameter and in strength you need to weld on an additional bracket to the steering arm. This configures the steering arm to double shear. I doubt you will be able to obtain this adapter unless you by the complete bolt kit and steering system upgrade? The next option is to have a machinist turn a "heim Extension Pin" to fit into the taper of the steering arm. Another option is to ream out the steering arm to a taper of a larger rod end, say an FJ-80 or Chevy or something bigger and beefier. Lastly, you can hog out the taper to a straight bolt, of say 5/8" but this large diameter bolt may limit the angle to hi-mis spacer and to the joint. If you search here on YT you can find a post I wrote about these steering complications.
