help please ECM
Old Feb 3, 2019 | 09:24 AM
Co_94_PU's Avatar
If you are still setting code eleven, you are chasing a power problem IE something is loose, a wire is broken, your efi relay is opening (likely due to the first two).
Clean the power cables, clean the grounds, ensure the electrical connection is clean and firm.
Old Feb 3, 2019 | 12:00 PM
michael1952's Avatar
how would you recommend cleaning them
Old Feb 3, 2019 | 03:35 PM
87-4runner's Avatar
wire brush, small dremel grinder wheel get them to clean unpainted metal... you can use some dielectric grease to keep it from rusting
Old Feb 4, 2019 | 04:36 AM
could the relay ITSELF be all thats causing my problem and nothing else?
its a cheap enough try....
Old Feb 25, 2019 | 02:22 AM
  #25
truck ran like new for 2 weeks NO problem then BOOM problem is back.....does this info help with what problem may be?
WFO
3.4 Swaps
13
Apr 16, 2014 12:17 PM
denpacc
May 29, 2008 07:13 AM
Michigan Mud Farmer
Mar 7, 2008 05:19 PM
stormy76
Oct 15, 2007 06:05 PM
