HELP! Overheated and white smoke is everywhere.
Well, I'm doing mine now, heads are off and i'm now cleaning the surfaces, I'm gonna use Toyota head gaskets only the rest will be aftermarket (just need time to find a 3.4 to swap the 3.0 out anyway). I'll even use the same bolts.
My question is, does anybody know how tight the head bolts go and in what sequence should I tigheten them?
Umm. If the head bolts are original Toyota , you 'll need new ones. The Toyota original headbolts are torque-to-yield (single use only).
Haynes manual or, preferably, the FSM will have the sequence and torque. Many heads are torqued 3 times when installing,, to get them up to proper, final torque.
Look here for more info:
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Mike in AR
Mike in AR
thanks.
hey guys thank you for all your help. I've been lucky enough to locate a 3.4L with only 45,xxx miles for 1200 so im gonna do the tranny swap and start the engine swap after i locate the rest of the components i need. wish me luck.
Mike in AR
Mike in AR
Now, assuming they are factory, What would the consequences be if I reuse them? I really don't want to take the cams off.
thanks !!!
dzldust
7
Oct 6, 2015 05:39 AM
charlie_fong
Sep 27, 2015 10:06 PM
