HELP! Overheated and white smoke is everywhere.
Old Mar 27, 2006 | 12:19 PM
rafael's Avatar
Well, I'm doing mine now, heads are off and i'm now cleaning the surfaces, I'm gonna use Toyota head gaskets only the rest will be aftermarket (just need time to find a 3.4 to swap the 3.0 out anyway). I'll even use the same bolts.
My question is, does anybody know how tight the head bolts go and in what sequence should I tigheten them?
Old Mar 27, 2006 | 04:09 PM
regularguy412's Avatar
Umm. If the head bolts are original Toyota , you 'll need new ones. The Toyota original headbolts are torque-to-yield (single use only).
Haynes manual or, preferably, the FSM will have the sequence and torque. Many heads are torqued 3 times when installing,, to get them up to proper, final torque.
Look here for more info:
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Mike in AR
Old Mar 27, 2006 | 05:26 PM
s t A t i c's Avatar
thanks.
hey guys thank you for all your help. I've been lucky enough to locate a 3.4L with only 45,xxx miles for 1200 so im gonna do the tranny swap and start the engine swap after i locate the rest of the components i need. wish me luck.
Old Mar 27, 2006 | 10:11 PM
rafael's Avatar
Mike in AR
That's a good question, all i know is that the recall was done to my truck back in 1998 and that the bolts use a thick washer and a 12 point 12mm socket to get them out.
Now, assuming they are factory, What would the consequences be if I reuse them? I really don't want to take the cams off.
thanks !!!
Old Mar 28, 2006 | 04:18 AM
  #25
I think for the difference in price, I'd just go with new head bolts and not have to worry. If Toyota did the HG recall replacement, they may have used the same style , single-use bolts.
Mike in AR
ladybugRC
458
Aug 21, 2020 10:41 AM
puddlepirate
Jul 30, 2016 06:29 PM
alexcarey
Oct 14, 2015 06:05 PM
dzldust
7
Oct 6, 2015 05:39 AM
charlie_fong
Sep 27, 2015 10:06 PM
