Help me guess this fluid. I dont think its oil
Old Aug 5, 2008 | 03:30 PM
simpsons721's Avatar
The fluid is a dark rusty brown it is leaking from very slow but leaking
right under in the middle of the big crossmember at the position you place you jack
my car is going through violent squeling that just started and im trying to fix it also the leak is coming from the middle but more towards the passenger side
Old Aug 5, 2008 | 03:35 PM
JasonWin's Avatar
a picture would really help, also I don't exactly understand your description...
Old Aug 5, 2008 | 03:43 PM
Jay351's Avatar
What does it smell like?
It could be:
Motor oil (will smell like gas)
Power steering leak (should be ATF fluid)
Or your front differential (oil should smell pretty bad)
Old Aug 5, 2008 | 03:55 PM
i guess it might be just oil
Old Aug 5, 2008 | 04:17 PM
PCE91V64x4's Avatar
if it is associated with the squeal it could be power steering fluid.
How are your brakes? It could be the brake fluid that came in the truck new as well.
Old Aug 5, 2008 | 04:28 PM
T-1000's Avatar
Low Power Steering fluid makes more of a groan than a squeal...Unless it's really low, then you can hear the pump chatter. My 4Runner drinks power steering fluid like a fish does water.
Old Aug 5, 2008 | 04:30 PM
InternetRoadkill's Avatar
You sure it's not just dirty rusty water from inside the frame that's leaking out?
Old Aug 5, 2008 | 04:55 PM
its like a scratchy squeal noise but it sounds like its coming from the drive shaft (middle of car)
Old Aug 5, 2008 | 10:53 PM
Keith B.'s Avatar
FYI, the big crossmember under the trans/tfr is not a jack point.
Old Aug 5, 2008 | 10:55 PM
CJM's Avatar
CJM
Rusty brown, kinda slick, smells burnt? Trans fluid, power steering is leaking or the trans.
Go get some brakleen and clean it all off then watch for where it comes from.
Old Aug 5, 2008 | 11:29 PM
abecedarian's Avatar
under which crossmember? I've got a few under mine.
is the leaking fluid thick, thin, slick, sticky? ... have a sulfur smell?
and is it auto, manual? scratchy / squeal could be torque converter or clutch throwout / release bearing.
hard to diagnose sounds heard from keystrokes on someone else's computer.
Old Aug 6, 2008 | 01:30 AM
toyminator2000's Avatar
hmmmmm. What does it taste like?
Old Aug 6, 2008 | 02:56 AM
chicken
Old Aug 6, 2008 | 06:33 AM
Matt16's Avatar
Probably automatic transmission fluid, BUT that could be from the PS pump or the tranny. Remember that Toyota uses automatic transmission fluid instead of PS fluid, so don't add the former. Is the PS reservoir low? The transmission cooler is near th rad I believe to that would be a logical place for the leak. I guess the first question should have been, Do you have a AT or 5spd?
Old Aug 6, 2008 | 07:03 AM
dirtoyboy's Avatar
Originally Posted by abecedarian
chicken
squirrel
jasonty
41
Dec 23, 2018 01:00 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Toyvana
Jul 29, 2015 10:47 PM
calderp
Jul 27, 2015 09:58 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
