Help !!! JUST DID OIL CHANGE, TRUCK WONT RUN
Old Oct 31, 2015 | 02:15 PM
davidsalas's Avatar
Just did oil change on my 92 pick up 4x4 4cyl 5spd.. I did all the correct steps, put new oil and filter now my truck won't run.. it turns on and everything but it turns off ...if I keep my foot on the accelerator it won't turn off but as soon as I let it go it turns off... Plus, when I first changed the oil I let the engine run for about ten minutes and it was fine. Took it for a drive and at my first stop sign it turned off... Any insight on what it could be ??? Thanks guys
Old Oct 31, 2015 | 03:07 PM
Obmi's Avatar
Sounds to me like a vacuum line got knocked loose.
Old Oct 31, 2015 | 03:17 PM
davidsalas's Avatar
I went with sae 10w-30 castrol gtx.. is it too thin ? That's what I've been told
Old Oct 31, 2015 | 03:18 PM
davidsalas's Avatar
I'm going to look into that as well thanks
Old Oct 31, 2015 | 03:43 PM
voiddweller's Avatar
Probably vacuum line ^^
Old Oct 31, 2015 | 03:58 PM
davidsalas's Avatar
Found the problem, plz disregard this thread
Old Oct 31, 2015 | 04:04 PM
What was it?
Old Oct 31, 2015 | 04:55 PM
Lzryde's Avatar
Probably a brain fart. We all have them
Old Oct 31, 2015 | 06:48 PM
anndel's Avatar
Yeah what was it?
Old Nov 1, 2015 | 04:05 AM
ThorInc's Avatar
Come on, share the experience, would love to know what the issue was?
Old Nov 1, 2015 | 07:11 AM
Odin's Avatar
Think this one out.
Explain your reasoning.
Were waiting
Old Nov 1, 2015 | 01:57 PM
wyoming9's Avatar
Red face
Come on fess up we want to know??
Your not the only one who has missed simple things .
Old Nov 2, 2015 | 09:26 AM
Janos01's Avatar
Depending on the engine you have and climate, 10W-30 is fine for most. Otherwise, what was the issue?
Old Dec 16, 2015 | 09:12 AM
davidsalas's Avatar
Prior to the oil change, i had adjusted the idle screw and i tightened it all the way LOL to fix the surging idle which i threaded with teflon tape, thats why it would turn off . Im such a dunce
Old Dec 16, 2015 | 09:31 AM
anndel's Avatar
No worries, I've been there. The main thing is that you figured it out and solved that issue so now it's running great.
jumpersatthedoor
Oct 9, 2015 01:12 PM
dfarr67
Oct 8, 2015 08:22 AM
jdt79
Oct 7, 2015 10:56 AM
ClaytonL
Oct 5, 2015 10:23 AM
