Help identifying suspension parts pics included.
Old Apr 13, 2010 | 10:10 AM
Mr.Chumchal's Avatar
Hello everyone well I finally got the runner back on the road after rebuilding the top end, feels good again. I need to now focus on getting some of the important suspension parts replaced. The passenger side wheel has some wobble in it so I will be replacing the wheel bearings asap. Can someone please just tell me what the suspension parts are called that I have numbered. Thanks alot.
-Nick
Old Apr 13, 2010 | 10:11 AM
pretty sure 4 is the idler arm, am I correct?
Old Apr 13, 2010 | 10:19 AM
OutlawMike's Avatar
1. Relay Rod - There was a recall on these, you might get yours replaced for free. (also called a center link by some people)
2. Pitman Arm
3. Tie Rod - Identical side to side. You replace the tie rod ends, but can buy the adjusting sleeve also.
4. Idler Arm - These go out all the time, the bushings go bad in them.
Old Apr 13, 2010 | 10:33 AM
Thanks for the quick reply awsome. Yah I will have to check on that recall. Was wondering does anyone have a picture of where the 4x4 vac lines go. I must of mixed one of the lines up when putting everything back together because the 4x4 won't engage. I've done a little searching but have not found what i'm looking for, thanks again.
-Nick
Old Apr 13, 2010 | 12:02 PM
DeathCougar's Avatar
The vacuum diagram should be on a sticker under the hood. The line goes from a splitter off the intake, to a set of ADD vacuum switching valves, then down to the ADD actuator.
Old Apr 13, 2010 | 03:41 PM
pruney81's Avatar
The recall was for the steering relay rod but under the recall Toyota will replace the steering rod and both tie rod ends plus a free alignment if done correctly.
I would take it in.
Old Apr 14, 2010 | 09:01 AM
Yeah i'm pretty sure they already did those repairs on my truck. I remember when I checked with them for doing my head gaskets they said they did somthing with the suspension already. I'll check though would'nt hurt.
icentropy
Sep 16, 2020 02:47 PM
mskalmus
May 28, 2017 07:51 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
toyoda8488
Jul 5, 2015 10:18 PM
Vargntucson
Jul 4, 2015 12:15 PM
