Help identify this new squeal/rattle on my 92 pickup.
Old Jul 17, 2019 | 07:34 PM
caducus's Avatar
This new engine noise just started. Sometimes it's louder. Tends to (mostly) go away once I've warmed up and driven a bit. Sort of a belt-like squeal combined with a rattle. Some belt or pulley maybe?
Sounds like maybe it's coming from the alternator area, but I'm not sure. Honestly it's hard to describe, but a hundred miles ago the engine definitely started making a new sound and got louder, which is always a bit unsettling.
1992 toyota pickup, 4cyl 22re, 205k, 4wd, has A/C
Old Jul 17, 2019 | 07:52 PM
akwheeler's Avatar
take one belt off at a time and see if it goes away, just don't run it long without the water pump or the alternator. and turn the A/C on and off to see if it changes.
Old Jul 18, 2019 | 04:22 AM
snippits's Avatar
When was the last time you adjusted/tightened the belts? The do stretch over time. I have had to adjust a new alternator belt twice in two years...about once a year it needed to be tightened.
Old Jul 18, 2019 | 04:24 AM
Paul22RE's Avatar
5 Year Member
After you make sure it's not just a loose belt, spray some WD40 on each pulley one at a time until the noise goes away to figure out if it's a pulley.
Old Jul 18, 2019 | 07:08 AM
ev13wt's Avatar
5 Year Member
Keep driving. The chances it will self heal are pretty high. It's a Toyota.
If it falls off, you will know what to replace.
Originally Posted by Paul22RE
After you make sure it's not just a loose belt, spray some WD40 on each pulley until the noise goes away to figure out if it's a pulley.
Do you also spray oil on brake pads if they squeal?
Old Jul 18, 2019 | 12:02 PM
akwheeler's Avatar
Yeah... don't do that.
Old Jul 18, 2019 | 03:40 PM
caducus's Avatar
It's been about 8 months. They all feel pretty snug.
Old Jul 18, 2019 | 03:41 PM
caducus's Avatar
I blew a head gasket not too long ago. I'm trying to play it a little safer these days as stay on top of everything.
Maybe it's just whining for attention and if I ignore it, it'll stop?
Old Jul 18, 2019 | 03:53 PM
akwheeler's Avatar
Yeah... Don't do that either.
Does the noise change if you turn the A/C on and off?
Is the noise gone if you remove all the belts? It'll start and run fine for a couple of minutes with NO belts on, so this is an easy test.
If the noise is still there you need to look deeper, likely the timing chain slapping on the inside of the timing cover which will eventually wear through and leave you stranded with an even larger repair cost.
Old Jul 18, 2019 | 04:00 PM
caducus's Avatar
Sounds the same with or without A/C. Haven’t tested without the belts yet.
Timing chain guides were replaced with metal ones by a reputable Toyota truck shop at 168k.
Old Jul 18, 2019 | 04:11 PM
akwheeler's Avatar
According to your first post you have gone about 40K since then, I wouldn't rule out the timing chain guides based on that, even if it was a "reputable shop", ˟˟˟˟ happens and things break.
If the noise is gone with all the belts removed put them back on ONE at a time and you will narrow your problem down, water pump, alternator, A/C compressor, P/S pump, fan clutch, tensioner pulley.
Wiggle all of them while the belts are off looking for play, spin what you can feeling for roughness, listen for growling or clicking.
Old Jul 18, 2019 | 04:19 PM
Paul22RE's Avatar
5 Year Member
Haha, pulley bearing, not the belt!
10 Gauge
Nov 13, 2014 03:05 PM
toyotanick
Oct 1, 2012 06:33 PM
toyotatom93
Mar 25, 2008 02:41 PM
Ursa Americanus
Oct 15, 2004 12:29 PM
