Help 86 Toyota pickup stuck in neutral
Old Mar 26, 2023 | 07:48 PM
Nativewrights's Avatar
I recently took my 1986 Toyota pickup custom cab into the snow. I went to engage 4wd and lock the manual hubs. And I drove it for a bit, barely a minute and seem to have lost all gears besides park. No grinding or anything. Neutral safety switch seems to be fine as I can start the truck back up. Tried rolling it back and forth, disengaging hubs and 4wd but to no avail no gears. It is a turbo auto tranny. Fluid looks fine with reddish color. Just stumped on what to do next. Any suggestions anyone ? Could really use any pointers.
Old Mar 27, 2023 | 06:18 PM
snippits's Avatar
Not a 4WD drive man. It could possibly be linkage binding, or just got disconnected. Need to have a person work the shifter while you are under it to see if the linkage is working right.
I have had linkage bind on a four speed Ford pickup, and best I can remember linkage coming loose on a few automatic transmissions over 45 years that I have owned vehicles.
Old Mar 27, 2023 | 06:24 PM
I have checked the linkage and they are all still connected and moving through all gears. Even moved them manually. Even had someone check while I was under and they are all function as should.
Izzyridin
Nov 7, 2019 07:40 PM
Yotahuntingrig93
Nov 2, 2015 11:39 PM
Yotahuntingrig93
Nov 1, 2015 10:11 AM
TSB
Oct 12, 2005 06:43 AM
ayoung101
7
Sep 30, 2005 08:24 PM
