Help with 1993 Truck Fuel Pump
Old Nov 23, 2013 | 11:15 AM
Weidle's Avatar
Hello I am having problems with my 1993 3.0L Toyota Trucks fuel pump. It recently stopped working the other day. It started out I could Jump the Fp terminal and the B+ terminal and the pump would run and the truck would start. I looked around and worked on some of the wiring and found out I had a bad relay for the fuel pump so i replaced it with a new one. Now the truck wont start at all and i cant even get the fuel pump to work when I jump the Fp and the B+ terminals. I am getting frustrated beyond belief at this point i replaced both of the relays and I dont know what to do. Thank you
Old Nov 23, 2013 | 03:33 PM
Cyberman's Avatar
Fuses all good?
Old Nov 24, 2013 | 07:34 PM
scope103's Avatar
Don't guess; use a multimeter. No excuse not to have one http://www.harborfreight.com/7-funct...ter-98025.html Check to see that you have 12v to ground at the B+ terminal (w/key on). If not, suspect the EFI fuse, the IGN fuse, or the EFI Main Relay (in that order).
Old Nov 24, 2013 | 09:20 PM
Weidle's Avatar
Thank you guys for your help. I had a couple of things wrong. I had a bad 80 amp fuse. i replaced that and then I used a multimeter on the B+ terminal and I was only getting 6 volts. I jumped my truck and it would run. Turns out i had a bad battery too. I guess when it decided to break down multiple things went. Thank you guys very much for all of your help
Old Nov 25, 2013 | 06:20 AM
scope103's Avatar
Thanks for the wrap up. Too often an interesting problem is presented, and we never know what happened in the end.
Old Nov 25, 2013 | 07:18 AM
ksti's Avatar
^X2
It's always a plus when OP's post up there fix.
Cut's down on the redundant questions.
puffin04
Jul 10, 2015 09:17 PM
rbravo1
Jun 29, 2015 01:34 PM
kazuya2416
Jun 27, 2015 12:24 PM
Mutinebullfrog
Jun 18, 2015 01:36 PM
Dennis140
Jun 17, 2015 10:37 AM
