Hello take a look at my 4Runner
things i need to do:
- install oil pressure reducer to feed line for tubo
- replace the idle control screw (mine somehow fell out and have one from a porsche stuck in there)
- clean up all turbo and intercooler piping preferably with some hardlines and cut the number of couplers by about 2/3
- replace lower kickpanel on drivers side
- new seats would be nice
- a small tack that i could mount in the gauge cluster would be awesome
lmk what you all think?
edit: one more thing to fix, master cylinder
http://www.truckpillars.com/
I thought of this site if you want to add guages. I haven't tried them yet. Don't know if I will. My SR5 has almost everything already.
It probably should be protected, but im used to driving a slammed vw that tore up oilpans regularly, i think i can avoid smashing things with the front end :knock on wood: We do not have front tags in SC.
4runnerx3 Did you install the turbo and intercooler yourself?
No i bought this from a friend that did that work. It has a garret T3 and we have been playing with the afm to get it running good at 6psi and usually no fuel cut-off problems. I looked around the junkyard for some other toyota afms that might be compatable, or modded to work, but nothing good yet. I need to plumb the afm back into the airbox (running with no element now
) but it is not my dd, just a toy
thats what i was looking for, but there just arent many around in junkyards anymore. i am going to check ebay and these forums, if i can get a decent sds system i might just junk the ecu altogether since it is really primitive.
Flying91
45
Apr 11, 2024 04:39 PM
BeMiceElf
Oct 10, 2015 09:40 PM
