Hella 500 wiring clarification (searched)
Old Sep 13, 2006 | 06:29 PM
BAZ's Avatar
BAZ
OK, I am in the process of installing these driving lights and the wiring seems pretty straightforward except the green wire. I realize there are many different ways to wire the lights and I have decided to either wire them to the hight beams or the parking lamps. (preferably the latter of the two) How do I find this wire and how exactly do I go about connecting the two.
Sorry for the amateur questions, I am wiring retarded.
Old Sep 13, 2006 | 08:11 PM
BAZ's Avatar
BAZ
OK, so I've kinda figured out whats going on. I pulled the corner lights and found the wire colors (white w/black stripe and red dashes, and green w/red dashes). I need to find the same wires behind the dash somewhere, which one do I tap into and where are the wires found?
Old Sep 13, 2006 | 08:15 PM
Bob_98SR5's Avatar
barry,
i got a great modified hella wiring chart. look in the tech section's electrical forum and find my writeup
bob
Old Sep 13, 2006 | 08:29 PM
BAZ's Avatar
BAZ
Bob, I'm actually looking at the diagram right now. My only problem is locating the parking light wires in the cab so I can wire the switch up. Any pointers on where these wires are? I cant for the life of me find them. Does it matter if i use the green one or the white one or should I be using both?
Thanks.
Old Sep 13, 2006 | 08:43 PM
Bob_98SR5's Avatar
baz,
why the parking light wire? how about a 12v acc wire? regardless, check out the12volt.com and find the wiring database engine thing. it'll tell you all the wiring colors
bob
Old Sep 13, 2006 | 08:57 PM
Elton's Avatar
i never like the idea of haveing the lights only come on with the hi beams so i wired mine so i can turn them on when i want to
Old Sep 14, 2006 | 10:31 AM
BAZ's Avatar
BAZ
So I went to bed frustrated and tired, woke up and traced my ignition wire from the fuse box and hooked everything up. They work! Now I just need to clean up my wiring a bit under the hood and aim them later tonight.
Thanks guys.
Old Sep 14, 2006 | 10:41 AM
04 Rocko Taco's Avatar
I'm with Elton on this one. I want to use my lights, when I want them...it makes wiring much easier too...all you need is the battery, and a switch...they CAN be totally independent of anything else on your truck. Although I would recomend running through an acc wire, or the wiper fuse or something, so that they DO go OFF when the truck does. Just my 2 cents here.
Old Sep 14, 2006 | 11:28 AM
Tacoclimber's Avatar
Yup... I agree. I wired mine so that I can turn them off and on when I want to.
Old Sep 14, 2006 | 02:29 PM
Calbo's Avatar
I found and bought a 3-way toggle switch. The center position is off, "up" position is on (regardless of ignition), and down position is on-with-high-beam.
In any case, glad to hear BAZ figured it out. Feels good, don't it?
Old Sep 14, 2006 | 02:38 PM
Ooooh, I like that idea. I didn't even think about doing that. I may be rewiring those bad boys soon!
Old Sep 14, 2006 | 02:48 PM
SoiledGreen98's Avatar
I wired mine so they can come on without hi-beams also. Then my 5 year old son, soon to be mechanic, turned my lights on and melted my plastic covers. Oops
Old Sep 15, 2006 | 12:54 PM
BAZ's Avatar
BAZ
Update!
...so everything looks nice and clean, lights work. I'm trying to aim them and it appears that one light is throwing a different light pattern than the other. The driver side looks egg-shaped and the passenger side is round. Kinda stumped as to why they're doing this.I tried pivoting the lights in different directions but one is still ovular while the other is a perfect circle.
Any ideas??
Old Nov 13, 2006 | 10:13 AM
da_bigg_wigg's Avatar
Maybe one is a fog and the other a driving light?
Old Nov 13, 2006 | 10:36 AM
lr9788's Avatar
well now that you have lights installed, lets see some pictures
MO transplant
Apr 23, 2023 11:58 AM
Regency
20
Jan 3, 2020 07:43 PM
raptor510
Feb 17, 2017 07:11 AM
smiley52
Jul 11, 2015 05:16 AM
toyota32
Jul 6, 2015 05:42 PM
