Heater Problem 22re no heat
Old Dec 11, 2012 | 02:15 PM
Peterbilt17's Avatar
hello everyone,
i have a 92 toyota pickup with a just rebuilt 22re.
The Problem: is i have no hot air blowing from the vents with the switch on high, just luke warm air.
Checked Already:
control valve works
heater lines are both hot
burped the system 3 times
engine temp is good
thermostat is good
if anyone has any input on whats wrong it would be greatly appreciated
Thanks
Old Dec 11, 2012 | 02:38 PM
vtjeenyus's Avatar
up under the passenger side dash there are control wires for the doors in your heater. maybe the one for hot cold air is stuck halfway, happened to me, pulled the cable and the door shut with only hot air blowing. then in the summer pull the cable back the other way for cold air. pita but it works .
Old Dec 11, 2012 | 04:00 PM
92 TOY's Avatar
same concept, make sure the valve is working as you are adjusting the temperature from inside. are the levers hard to move?
Old Dec 11, 2012 | 04:32 PM
Thanks ill check the heater door in the morning. And yes the heater valve moves easily and is in working condition
Old Dec 12, 2012 | 05:53 PM
So I checked the door...it works ...still is blowing Luke warm air....
Anyone else know what's could be wrong?
any help would be great....I live In Wisconsin and its getting cold and I need it fixed ASAP
Thanks again
Old Dec 12, 2012 | 07:44 PM
BlacktoothGrin's Avatar
try to back flush your heater core, mine was the same way and i hooked up a hose a backflushed it(blew water IN through the OUT hose) buncha gunk flew out and it seemed to help a bit.
Old Dec 5, 2017 | 06:53 AM
4RunnerTexas's Avatar
I will try the back flush too. My '86 4X is doing the same thing. Really hot water both sides of the valve so the valve is working and flapper doors work too, but no hot air. And the return water hose is not hot. The core has to be plugged up.
Old Dec 5, 2017 | 07:51 AM
Melrose 4r's Avatar
5 Year Member
I'll add myself to this list with similar lack of heat. I know it's not the thermostat just changed that.
But the heater core is 31 years old (probably) and we don't expect radiators to last that long so...
Old Dec 5, 2017 | 09:05 AM
akwheeler's Avatar
could be the fins on the heater core are plugged, rat's nest, leaves, dandelion fuzz, whatever.
Old Dec 5, 2017 | 07:32 PM
Co_94_PU's Avatar
Heater core needs to pass air as well as water
​​​​​​terry has a few good posts on this.
In short they catch all the debris from the cowl openings and might need vacuuming.
Old Dec 23, 2017 | 12:56 PM
Ok! It was the heater core that was plugged up. I took off the heater hoses and stuck some garden hose ends in them (5/8" male and female) and hooked up the garden hose so the water wouldn't blow all over the engine bay and back flushed it. (Remember to have your heater valve turned to open) All kinds of black greasy crud (glycerin) went all over my driveway. But hey!!! The heater works great now and will roast yer butt off. It works best if you have one of them on/off valve adapters right at the return outlet so you can control water flow right in front of you instead of having to run to the hose spigot. I also left the pressure side of the garden hose connected to the return heater hose while reconnecting the heater supply hose. after connecting the supply, I removed the radiator cap and ran a bit of water back through the engine to remove any air bubbles that may have gotten into the system. Not too much though, because you don't want to degrade your anti-freeze.
Old Dec 26, 2017 | 03:27 PM
Melrose 4r's Avatar
5 Year Member
Glad to hear you got it!
I'd love to try the same with mine but it's way too cold outside to be playing with water right now.
Old Dec 26, 2017 | 04:09 PM
muddpigg's Avatar
I’ve about given up on a replacement core. They are either the wrong dimensions or lines won’t mate to core.
Over the years I’ve back flushed, flushed, soaked in acid... Tomorrow i’ll take it to a radiator repair shop and with luck they can fix it.
Old Dec 27, 2017 | 09:12 AM
RAD4Runner's Avatar
Always a good idea to back flush the heater core. I started making it a routine part of my cooling system flush rinse phase. Like 4RunnerTexas, I also connected the garden hose / squeezed radiator hoses various ways to force rinse water to flow opposite the normal coolant flow.
I also do the "heavy-duty flush" as described on container of Prestone flushing solution. Filled system with flushing solution, went on road trip and rinsed and re-filled with coolant upon my return.
Both of the above are additional work but well worth it.
The grille on the cowl is poor design. It let's thin / slender leaves / debris in, then those get trapped at the drain. I plan to install plastic gutter screen (Amerimax brand from Home Depot, attached) right below the grille.
Attached Thumbnails Heater Problem 22re no heat-20161020_163838_prestone_heavydutyflush.jpg   Heater Problem 22re no heat-gutter_guard.jpg
Old Dec 27, 2017 | 09:20 AM
Melrose 4r's Avatar
5 Year Member
Just curious what you guys do with all your "flushed" antifreeze. I am not the greenest guy in Massachusetts but am trying to be more environmentally friendly and my local O'reillys here told me they don't take back old antifreeze and i am not about to dump it on my driveway.
Old Dec 27, 2017 | 09:40 AM
RAD4Runner's Avatar
Antifreeze / Coolant Disposal
Originally Posted by Melrose 4r
... am trying to be more environmentally friendly and my local O'reillys here told me they don't take back old antifreeze and i am not about to dump it on my driveway.
Each county should have guidelines AND RESOURCES for proper disposal of coolant. San Diego County for example has guidelines (here), BUT (a resounding BUT) lists very few and far places that take used antifreeze. Does it really expect people to drive over an hour (round-trip) to properly dispose of coolant?
So I guess we do what we think is best, given our resources and information we have: Could be toxic but bio-degradable.
Old Dec 27, 2017 | 03:23 PM
muddpigg's Avatar
I read on disposal of antifreeze if no local recycling available most water treats plants can clean it outing treatment process. Just not large quantities. If you’re on septic that does cause a problem.
Old Dec 27, 2017 | 04:35 PM
mldave's Avatar
https://www.google.com/search?hl=en&...56.jzhRyPmhfig
jbv808
Aug 6, 2021 04:47 PM
Sleaker
Aug 26, 2020 06:03 AM
BeMiceElf
Oct 10, 2015 09:40 PM
msane99
Jul 17, 2015 10:13 AM
Poncho0206
Jul 10, 2015 06:21 PM
