Headlights suggestion
Old Feb 23, 2021 | 05:28 AM
MaK92-4RnR's Avatar
Stick with the sealed beams and save some money. It's like $5.00 for a headlight retail.
Old Feb 23, 2021 | 09:46 AM
RAD4Runner's Avatar
Sensible advice, BUT fix convoluted power path with conversion harness. Stock circuit is proven BAD. Ask me, Ask 4Crawler. Fixing that is most essential before any upgrade, especially if using higher wattage bulbs thab stock.
Old Feb 23, 2021 | 10:02 AM
MaK92-4RnR's Avatar
Oh i know it needs a harness. @space-junk installed conversion headlights on his 87 4Runner without a harness and stuff we haywire. I think his brake pedal was illuminating his interior/dash lights? I don't remember.
I just stick with the sealed beams. I live in the city. If I go anywhere that requires upgraded lighting, i just hunch over a little bit more to reach a switch that turns on all the LEDs on the front bumper.
Old Feb 23, 2021 | 11:44 AM
space-junk's Avatar
brake pedal issue is not related to the head lights. the issue with the truck-lites was that the momentary high beams would work fine, but the full highbeam itself would just flicker very dimly. Conversion harness fixed it and now they work amazingly well. i wouldnt ever go back to sealed beam head lights. hands down best investment thusfar. especially since Doomy has pretty bad night sight due to her terrible eyesight; i consider this a mandatory safety upgrade. Also, we have never been flashed with these on low, but it sure gets peoples attention when i need to flash my highs at them!
Old Feb 23, 2021 | 01:05 PM
  #25
MaK92-4RnR's Avatar
You got links to the harness/headlights? i'd be interested in seeing how much everything was.
Old Feb 23, 2021 | 02:37 PM
  #26
Blueman's Avatar
Huh. I've not had any issues with the harness that Mama Toyota gave mine. Are there lots of people having issues with the original harness with factory wattage lamps?
Old Feb 25, 2021 | 09:53 AM
  #27
space-junk's Avatar
you probably havent noticed, but i can guarantee you that over time from corrosion and use, your headlights are getting dimmer. toyota ran power through the switch on the column and thats a looooooong convoluted path for the power to wind. Upgrading the circuits with relays to fire the lows and highs(drawing clean power directly off the battery) is a much more sensible option than having to rely on the stock harness to carry the load.
as for the setup i have, @MaK92-4RnR , its just a set of trucklites(i dont think theyre called that anymore?) and a 25 dollar conversion harness from amazon. they work amazingly well.
Old Feb 25, 2021 | 10:11 AM
  #28
MaK92-4RnR's Avatar
Same here.
The $300.00 version or the $569.99 version?
Old Feb 25, 2021 | 08:03 PM
  #29
RAD4Runner's Avatar
... thats a looooooong convoluted path for the power to wind. ..
...its just a set of trucklites(i dont think theyre called that anymore?) and a 25 dollar conversion harness from amazon. they work amazingly well.
Yup, about 15 feet of thin wires and ... as 4Crawler puts it (here)...
Old Feb 25, 2021 | 08:05 PM
  #30
space-junk's Avatar
Same here.
mine were about tree fiddy after taxes and such.
Old Feb 26, 2021 | 07:58 AM
  #31
MaK92-4RnR's Avatar
Dang, dude.
cheap-ass
Jul 30, 2011 08:52 PM
w211_ryda
Jul 7, 2008 08:02 PM
pdyebrasil
17
Nov 27, 2007 08:54 AM
Jason B
9
Sep 26, 2006 05:34 AM
